I just received a K20c, with ecc off there is only 1G of global memory showing, With ecc on there is 700K of global memory showing. Im using the cudaGetDeviceProperties call. Also have a gtx 690 in the same box and the properties are correct on that card. Since there is supposed to be 5G of memory on the K20c do I have a defective card ?,
CUDA Device #0
Major revision number: 3
Minor revision number: 5
Total global memory: 737738752
Total shared memory per block: 49152
Total registers per block: 65536
Warp size: 32
Maximum memory pitch: 2147483647
Maximum threads per block: 1024
Maximum dimension 0 of block: 1024
Maximum dimension 1 of block: 1024
Maximum dimension 2 of block: 64
Maximum dimension 0 of grid: 2147483647
Maximum dimension 1 of grid: 65535
Maximum dimension 2 of grid: 65535
Clock rate: 705500
Total constant memory: 65536
Texture alignment: 512
Concurrent copy and execution: Yes
Number of multiprocessors: 13
Kernel execution timeout: No
CUDA Device #1
Minor revision number: 0
Name: GeForce GTX 690
Total global memory: 2147287040
Warp size: 32
Clock rate: 1019500
Number of multiprocessors: 8
CUDA Device #2
Total global memory: 2147155968
Warp size: 32
Clock rate: 1019500
Kernel execution timeout: Yes
[/code][img][img][s]
[/s][/img][/img]
