I am testing my gpu properties using cudaGetDeviceProperties. However, my global memory in bytes reports 0. Anyone knows what happened?
I ran the program on windows 10 64 bit, and my gpu is 1070.
Best,
Ziqi
Best,
Ziqi
What is the output of the deviceQuery sample code on your system?
Thank you for answering. Actually I found out the solution to the issue. It is because the print format is not correct.
