I just installed a Tesla S1070 and run deviceQuery (from CUDA SDK) on a connected host to verify the succeed of installation
There are 2 devices supporting CUDA
Device 0: “Tesla T10 Processor”
Major revision number: 1
Minor revision number: 3
Total amount of global memory: -262144 bytes
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1440000 kilohertz
Device 1: “Tesla T10 Processor”
Warp size: 32
Test PASSED
Press ENTER to exit…
All the output is sensible except the negative value of “Total amount of global memory”
Anyone know the reason?
