There is 1 device supporting CUDA
Device 0: “GeForce 8600 GTS”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 268173312 bytes
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1458000 kilohertz
Test PASSED
this was the output of device query command, but as a newbie i am not getting what exactly is this output, can somebody explain every term used in here?
and where are gpu’s ?how many gpu’s are there in this system?
