Could somebody explain an obviously incorrect output from deviceQuery and what’s more important provide me with a correct one for my GPU.
There is 1 device supporting CUDA
Device 0: “GeForce 8600 GTS”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 268107776 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.46 GHz
Concurrent copy and execution: Yes
