I am using a Mac Book Pro 13" 2009 with a GeForce 9400M on MacOs X Snow Leopard and Win7-32 (areo disabled).
In OSX I get the proper amount of global memory (254 MB) but not on windows, therefore I think the hardware should be ok.
Note, that it worked on CUDA 3.2.
Where the following is output by deviceQueryDrv.exe:
Device 0: “GeForce 9400M”
CUDA Driver Version: 4.0
CUDA Capability Major/Minor version number: 1.1
Total amount of global memory: 0 MBytes (0 bytes)
( 2) Multiprocessors x ( 8) CUDA Cores/MP: 16 CUDA Cores
GPU Clock rate: 1.10 GHz
Memory Clock rate: 1066.00 Mhz
Memory Bus Width: 64-bit
Max Texture Dimension Sizes 1D=(8192) 2D=(65536,32768) 3D=(
2048,2048,2048)
Max Layered Texture Size (dim) x layers 1D=(8192) x 512, 2D=(8192,8192)
x 512
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Texture alignment: 256 bytes
Maximum memory pitch: 2147483647 bytes
Concurrent copy and execution: No with 0 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Concurrent kernel execution: No
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: No
Device supports Unified Addressing (UVA): No
Device PCI Bus ID / PCI location ID: 2 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simu
ltaneously) >
[deviceQueryDrv.exe] test results…
PASSED
Press ENTER to exit…
I then switched to beta drivers where the same problem occurs.
Any ideas?
kind regards,
Martin
