Kubuntu (22.04.2) Not Detecting External Monitors with GeForce RTX 3050 Laptop GPU (525.105.17)
Hello everyone,
I am experiencing an issue with my laptop where external monitors are not detected when running Kubuntu on an NVIDIA graphics card. I have tried to reinstall all, firmware update, and different settings, but I do not get it working. The external monitor shows a dublication until the os takes over, so I guess it must be software related.
I will attach some informations to the text. I also have a bug report
nvidia-bug-report.log.gz (536.8 KB).
  • NVIDIA(G0): NVIDIA GPU NVIDIA GeForce RTX 3050 Laptop GPU (GA107-A) at
  • Driver Version: 525.105.17
  • Operating System: Kubuntu 22.04.2 LTS
  • Kernel Version: 5.15.0-69-generic (64-bit)
  • Integrated GPU: Intel Corporation Alder Lake-P Integrated Graphics Controller
  • Kernel driver in use for iGPU: i915
Thank you for reading and in advance for your help.
Timo
*** I REPOSTED THIS AS THE ORIGINAL TOPIC WAS SPAMFILTERED ***
system info
KDE Plasma Version: 5.24.7
KDE Frameworks Version: 5.92.0
Qt Version: 5.15.3
Graphics Platform: X11
Processors: 20 × 12th Gen Intel® Core™ i7-12700H
Memory: 62,5 GiB of RAM
Graphics Processor: Mesa Intel® Graphics
nvidia-smi
Mon Apr 24 11:05:09 2023
| NVIDIA-SMI 525.105.17 Driver Version: 525.105.17 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 36C P0 N/A / 60W | 5MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1522 G /usr/lib/xorg/Xorg 4MiB |
dmidecode
dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.3 present.
54 structures occupying 3485 bytes.
Table at 0x6F088000.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: INSYDE Corp.
Version: 1.07.15
Release Date: 08/19/2022
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 16 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 7.15
Firmware Revision: 7.5
uname -a
Linux HiddenSystem 5.15.0-69-generic #76-Ubuntu SMP Fri Mar 17 17:19:29 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
lspci -nnk | grep -iA2 vga
00:02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-P Integrated Graphics Controller [8086:46a6] (rev 0c)
Subsystem: CLEVO/KAPOK Computer Device [1558:0156]
Kernel driver in use: i915
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
The nvidia gpu has no outputs, all are on the intel igpu. Your hdmi not working is due to a known i915 bug with 12th gen cpus. Don’t know whether a fix exists yet.
Thank you that is already helping. Do you have maybe a link to the bug? If I understand it correct, I have to hope for a newer kernel fixing this bug?
I googled;
Possible this bug?
Do you know if any linux distribution can deal with it?
The general i915 or better said, common insyde bios bug had two effects
internal display not working after suspend
https://gitlab.freedesktop.org/drm/intel/-/issues/5531
which was fixed in kernel 6.3
hdmi port not working
https://gitlab.freedesktop.org/drm/intel/-/issues/7709
which wasn’t fixed yet (apart from a kernel hack)
The common workaround was to use a DP port on the notebook, if available.
Ok. That’s helping a lot.
I have an mini displayport, I will try that as soon as I get an adapter.
Maybe I will also try to compile the kernel with the hack, but not now.
Thank you a thousand times. Great help.
Timo
