First of all :)
nvidia-bug-report.log.gz (145.0 KB)
I have a dual boot Windows 11 with Ubuntu 22.04. My windows works fine and external monitors work with it.
Initially the built-in screen was not recognized by the OS, therefore I figured the problem was graphics. I have a HP Victus 16-e0007ni with a NVIDIA GeForce RTX 3050 Ti Mobi and build-in AMD Graphics. Here is a result of a command that might help.
~$ lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GA107M [GeForce RTX 3050 Ti Mobile] (rev a1)
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c5)
I then swapped from what was described in the Software & Update application as a custom installed driver. To proprietary NVIDIA drivers using
~$ sudo apt install nvidia-driver-510
~$ reboot
and similar commands (i.e. 470 et cetera), after testing all of them the same thing happened.
They fixed the problem of the laptop’s built-in display not being recognized, however none of them recognized my external monitor. Further, I tried the X.org drivers. Here it worked the first time I booted, however from then on I had to boot to safe mode first for it to boot in at all. So in conclusion I now switched back, using
~$ sudo ubuntu-drivers autoinstall
to nvidia-driver-515.
Anyway so here are a few suspicious things:
nvidia-smi throws this error. This leaves me to believe there is a error with loading the graphics driver.
~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Another suspicious output:
xrandr --listproviders
Providers: number : 0
This is my GPU-Manager log file
gpu-manager.log (27.2 KB)
These are the Nvidia packages I believe.
dpkg -l | grep nvidia
ii libnvidia-cfg1-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-515 515.65.01-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-470:amd64 470.129.06-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-510:amd64 510.73.05-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-515:i386 515.65.01-0ubuntu0.22.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-515:i386 515.65.01-0ubuntu0.22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-515:i386 515.65.01-0ubuntu0.22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-515:amd64 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-515:i386 515.65.01-0ubuntu0.22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc linux-modules-nvidia-515-5.15.0-41-generic 5.15.0-41.44+1 amd64 Linux kernel nvidia modules for version 5.15.0-41
rc linux-objects-nvidia-515-5.15.0-41-generic 5.15.0-41.44+1 amd64 Linux kernel nvidia modules for version 5.15.0-41 (objects)
rc nvidia-compute-utils-470 470.129.06-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-510 510.73.05-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-515 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-dkms-470 470.129.06-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-510 510.73.05-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-dkms-515 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-515 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-470 470.129.06-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-510 510.73.05-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-515 515.65.01-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-515 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-515 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-515 515.65.01-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
This I believe this confirms my Graphics card is picked up at least
sudo dmesg | grep -i hdmi
[sudo] password for raymond:
[ 0.308917] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 3.551965] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:06:00.1/sound/card1/input18
[ 3.552696] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input19
[ 4.516660] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input20
[ 4.516692] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input21
[ 4.516723] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input22
These are all the Graphics Drivers I tried with all the same problem of external monitor not displaying
~$ apt list | grep nvidia-driver
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
nvidia-driver-390/jammy-updates,jammy-security 390.154-0ubuntu0.22.04.1 amd64
nvidia-driver-390/jammy-updates,jammy-security 390.154-0ubuntu0.22.04.1 i386
nvidia-driver-418-server/jammy 418.226.00-0ubuntu4 amd64
nvidia-driver-418/jammy 430.50-0ubuntu3 amd64
nvidia-driver-430/jammy 440.100-0ubuntu1 amd64
nvidia-driver-435/jammy 455.45.01-0ubuntu1 amd64
nvidia-driver-440-server/jammy-updates,jammy-security 450.203.03-0ubuntu0.22.04.1 amd64
nvidia-driver-440/jammy 450.119.03-0ubuntu1 amd64
nvidia-driver-450-server/jammy-updates,jammy-security 450.203.03-0ubuntu0.22.04.1 amd64
nvidia-driver-450/jammy 460.91.03-0ubuntu1 amd64
nvidia-driver-455/jammy 460.91.03-0ubuntu1 amd64
nvidia-driver-460-server/jammy-updates,jammy-security 470.141.03-0ubuntu0.22.04.1 amd64
nvidia-driver-460/jammy-updates,jammy-security 470.141.03-0ubuntu0.22.04.1 amd64
nvidia-driver-465/jammy-updates,jammy-security 470.141.03-0ubuntu0.22.04.1 amd64
nvidia-driver-470-server/jammy-updates,jammy-security 470.141.03-0ubuntu0.22.04.1 amd64
nvidia-driver-470/jammy-updates,jammy-security 470.141.03-0ubuntu0.22.04.1 amd64
nvidia-driver-495/jammy 515.48.07-0ubuntu0.22.04.1 amd64
nvidia-driver-510-server/jammy-updates,jammy-security 510.85.02-0ubuntu0.22.04.1 amd64
nvidia-driver-510/jammy-updates,jammy-security 510.85.02-0ubuntu0.22.04.1 amd64
nvidia-driver-515-server/jammy-updates,jammy-security 515.65.01-0ubuntu0.22.04.1 amd64
nvidia-driver-515/jammy-updates,jammy-security,now 515.65.01-0ubuntu0.22.04.1 amd64 [installed]
No clue what this is what I saw someone else post (probably applicable on most of the information I have posted)
sudo lshw -c video
*-display
description: VGA compatible controller
product: GA107M [GeForce RTX 3050 Ti Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list fb
configuration: depth=32 latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:fe0-fdf iomemory:ff0-fef memory:fb000000-fbffffff memory:fe00000000-feffffffff memory:ff00000000-ff01ffffff ioport:f000(size=128) memory:fc000000-fc07ffff
*-display
product: Cezanne
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:06:00.0
version: c5
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list fb
configuration: depth=32 driver=amdgpu latency=0 resolution=1920,1080
resources: irq:45 memory:d0000000-dfffffff memory:e0000000-e01fffff ioport:c000(size=256) memory:fc500000-fc57ffff
