| Processes: |
| ID ID Usage |
| 0 N/A N/A 1375 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 1848 G /usr/lib/xorg/Xorg 4MiB |
Thanks for the reply Generix…
However, now the eGPU has stopped working. I guess this is related to other issues, but I would very much like some advice… It is detected with lspci, but does not appear in nvidia-smi…
nvidia-smi
Mon Aug 15 07:36:07 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| | | MIG M. |
| 0 Quadro RTX 3000 Off | 00000000:01:00.0 On | N/A |
| N/A 45C P8 12W / N/A | 119MiB / 6144MiB | 17% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1737 G /usr/lib/xorg/Xorg 22MiB |
| 0 N/A N/A 2199 G /usr/lib/xorg/Xorg 95MiB |
Thanks Generix,
I uninstalled 515 with software and updates, installing the open source driver. Restarted, rolled back to 450 with “software and updates”, set up prime, set on-demand, and restarted.
I’m still not getting the driver appearing on nvidia-smi.
I’m not sure if the magic element is using the “run” file…but I was not sure which one to use.
OK, I downloaded the run file, and tried to follow the readme as closely as possible.
Note that runlevel 3 in Ubuntu 20.04 is not accessed as described, and the only way I seemed to be able to get into runlevel 3 was via sudo init 3.
Modifying /etc/default/grub did not do the trick.
I made a blacklist file for nouveau.
I installed the 470.82 run file, and followed through the process.
I’m still not getting the eGPU (3090 Ti) listed with nvidia-smi.
