[KUbuntu 22.04 - iGPU + dGPU] Driver installation procedure
Dear all,
I’d like to setup KUbuntu 22.04 on a desktop PC configured with:
  • iGPU: Intel UHD Graphics 630
  • dGPU: nVidia GTX 1650
iGPU will be used for X11/graphics purpose instead dGPU for CUDA computational works.
Looking for the web, I follow this procedure
1. Bios Setup
I set VGA priority in this order: iGPU - PEG - PCI
2. KUbuntu 22.04 driver setup
Once ubuntu has been installed, I did the following steps:
1. disable nouveau driver by setting its blacklist-file
blacklist nouveau
options nouveau modeset=0
and then update kernel’s
sudo update-initramfs -u
2. download official nvidia driver from nvidia XFree86 link
3. disable sddm and switch to init 3 mode
sudo service sddm stop && init 3
4. installing nvidia driver without opengl files
sudo ./NVIDIA-Linux-x86_64-525.125.06.run --no-opengl-files
5. Update/Create /etc/X11/xorg.conf with this content:
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "intel"
    VendorName     "Intel Corporation"
    BusID          "PCI:0:2:0
EndSection
where PCI id has been set in accord to lspci command.
After this, I reboot the OS, X11 correctly started but when I try the command nvidia-smi, this raise the following error:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver
This procedure has been read from these links:
Am I forgetting any step? Where am I wrong?
Thanks,
Nicola
Dear All,
after some troubles, I think I’ve solved.
Here are all the steps for my configuration:
Apt required’s packages
sudo apt-get install -y --no-install-recommends \
   pkg-config \
   make \
   gcc \
   g++ \
   linux-headers-$(uname -r)
Installing driver using .run file
nvdriver=525.125.06
curl -fsSLO https://download.nvidia.com/XFree86/Linux-x86_64/$nvdriver/NVIDIA-Linux-x86_64-$nvdriver.run
chmod +x NVIDIA-Linux-x86_64-$nvdriver.run
Blacklist nouveau
echo blacklist nouveau | tee -a /etc/modprobe.d/blacklist-nvidia-nouveau.conf
echo options nouveau modeset=0 | tee -a /etc/modprobe.d/blacklist-nvidia-nouveau.conf
Driver installation
The thing that let my system work, is using --m=kernel-open option.
More info on these links:
sudo service sddm stop && init 3;
sudo ./NVIDIA-Linux-x86_64-$nvdriver.run \
   --no-opengl-files \
   --no-wine-files \
   --dkms \
   --m=kernel-open
then enable NVreg_OpenRmEnableUnsupportedGpus open kernel module option:
sudo echo options nvidia NVreg_OpenRmEnableUnsupportedGpus=1 | tee -a /etc/modprobe.d/nvidia.conf
Let X11 driven from Intel / Integrated GPU only
Copy the following inside /etc/X11/xorg.conf
   Identifier "layout"
   Screen 0 "intel"
EndSection
Section "Device"
   Identifier "intel"
   Driver "modesetting"
   BusID "PCI:0:2:0"
   Option "AccelMethod" "SNA"
EndSection
Section "Screen"
   Identifier "intel"
   Device "intel"
EndSection
Enable persistenced Daemon
From this link, you can initialize NVIDIA GPU and keep it enable even if there isn’t any X11 instance connected to it; this is available thanks to nvidia persistenced daemon.
Using systemctl, you can enable this daemon just creating this file inside /etc/systemd/system:
[Unit]
Description=NVIDIA Persistence Daemon
Wants=syslog.target
[Service]
Type=forking
ExecStart=/usr/bin/nvidia-persistenced --user %HERE-PUT-YOUR-USERNAME%
ExecStopPost=/bin/rm -rf /var/run/nvidia-persistenced
[Install]
WantedBy=multi-user.target
and enable it
chmod +x /etc/systemd/system/nvidia-persistenced.service
systemctl reenable nvidia-persistenced.service
Test Setup
Check if everything works in this way: nvidia-smi
and the output should be:
| NVIDIA-SMI 525.125.06   Driver Version: 525.125.06   CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:01:00.0 Off |                  N/A |
| 50%   33C    P8    N/A /  75W |      6MiB /  4096MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
That’s all
Nicola
