I was on a call with an HPE rep discussig the merits of L4 vs L40 and L40s. The engineer said that L40 and L40s were not a good fit for vPC. I had planned on using L40s for the L40s-2B profile and fit up to 24 VDI on each card with a 2GB GPU profile. The engineer said that L4 was better for vPC due to some queueing mechanism but he couldn’t go any deeper than that. Based on everything I see, the L40s is compatible and provides a B series profile, so besides Power, Form Factor and Cost, why should I not use it over the L4. It takes 4 L4s to run same density as 2 L40S and not many chassis support 4 L4 (besides HPE GPU Chassis, but that might not be an option for other reasons).
Related topics
| Mix L4 and L40 for vGPU POC | 4 | 1461 | October 26, 2023 | |
| NVIDIA VGPU for L40s baremetal | 0 | 537 | October 28, 2024 | |
| VMWare VGPU GRID drivers for L40S GPU | 0 | 1228 | April 17, 2024 | |
| L40S unavailable when other GPUs are present on ESXi host | 5 | 1023 | February 5, 2025 | |
| L40S VMware Linux Setup and Licensing | 1 | 587 | February 8, 2025 | |
| Configure the Nvidia VGPU profile on L40s | 0 | 392 | May 20, 2025 | |
| Nvidia L40S overheating and exclamation mark in device manager | 4 | 715 | December 21, 2024 | |
| vGPU software not recognizing L4 card | 0 | 116 | November 17, 2025 | |
| Passthru and vGPU Problem with L40s | 4 | 1874 | June 3, 2025 | |
| Selecting the Correct vGPU Profiles | 0 | 215 | March 27, 2025 |
