Mix L4 and L40 for vGPU POC
Hi there,
is it possible to use vGPU with a L4 and a L40 in one server hardware for a POC? We want to compare a VDI Solution with these cards and provide Win and Linux VDI VMs with different underlying cards.
ty
Kevin
No one with same requirements there?
Do you want to know if this would technically work? Mixing different GPUs in the same host is not supported from the OEM but from a Nvidia driver perspective it will work.
Thank you for the answer.
So for just a POC, i can use both cards in parallel providing different vGPU profiles (same profile for each GPU) to a VDI POC?
Correct.
