Mixed vGPU profiles
Can someone confirm that mixed profiles are not supported on a single GPU? I’m aware this was not supported in K1/K2 GPUs but hearing some mixed messages in regard to M6/M60 GPUs.
Could you please explain what you achieve - One GPU as passthrough and reaming as vGPU profiles on single M60 card ?
Hi Nealus,
I can confirm that you still cannot mix different framebuffer size profiles with GRID 2.0 on the M60 and M6.
What mixed messages are you getting?
Hi - thanks for the responses. I have tried different profiles on the M60/M6 and do indeed get the expected errors when booting the vGPU VMs in View. I can’t be sure, but noted some discrepancy between the older GRID hardware and the new. I must have been wrong, but thanks for the clarification
thanks
Confirmed.
Mixed vGPU profiles on the same GPU will not currently work / are not currently supported.
It’s not even something you can try, as the vGPU Manager on the Hypervisor will only allow a single vGPU profile on a GPU once a VM has been started.
Ben
Hi all,
I wonder if you can still only use the same GPU profile on a GPU or has anything changed in the meantime?
There is no change yet. Only exception is A100 where you can run different profiles due to MIG feature.
