Setup: RHEV 4.2 on RHEL 7.5
We have an Nvidia M60 that shows available vGPU instances on only one of the GPUs on the hypervisor. We only have a few VMs configured to use vGPUs, so it shouldn’t account for why no instances are available. The guide mentions that 0 instances may appear if there is an ‘instance of another vGPU type already exists on the physical GPU’. What other vGPU type could exist on the GPU, and how would I tell?
The logs shows that there are vGPU instances on both GPUs (00:86:00:0 and 00:87:00:0)
Mar 6 12:20:53 dev1 kernel: nvidia: loading out-of-tree module taints kernel.
Mar 6 12:20:53 dev1 kernel: WARNING: module ‘nvidia’ built without retpoline-enabled compiler, may affect Spectre v2 mitigation
Mar 6 12:20:53 dev1 kernel: nvidia: module license ‘NVIDIA’ taints kernel.
Mar 6 12:20:53 dev1 kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Mar 6 12:20:53 dev1 kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
Mar 6 12:20:53 dev1 kernel: nvidia 0000:86:00.0: enabling device (0100 -> 0103)
Mar 6 12:20:53 dev1 kernel: nvidia 0000:87:00.0: enabling device (0100 -> 0103)
Mar 6 12:20:54 dev1 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 410.91 Wed Dec 19 05:57:36 CST 2018 (using threaded interrupts)
Mar 6 12:20:54 dev1 systemd: Starting NVIDIA vGPU Daemon…
Mar 6 12:20:54 dev1 nvidia-vgpud: Verbose syslog connection opened
Mar 6 12:20:54 dev1 nvidia-vgpud: Started (1562)
Mar 6 12:20:54 dev1 nvidia-vgpud: Global settings:
Mar 6 12:20:54 dev1 nvidia-vgpud: Size: 16#012Version 1
Mar 6 12:20:54 dev1 nvidia-vgpud: Homogeneous vGPUs: 1
Mar 6 12:20:54 dev1 nvidia-vgpud: vGPU types: 203
Mar 6 12:20:54 dev1 nvidia-vgpud: pciId of gpu [0]: 0:86:0:0
Mar 6 12:20:54 dev1 nvidia-vgpud: pciId of gpu [1]: 0:87:0:0
Mar 6 12:20:54 dev1 systemd: Starting NVIDIA vGPU Manager Daemon…
Mar 6 12:20:54 dev1 systemd: Started NVIDIA vGPU Daemon.
Mar 6 12:20:54 dev1 systemd: Started NVIDIA vGPU Manager Daemon.
Mar 6 12:20:56 dev1 nvidia-vgpu-mgr[1619]: notice: vgpu_mgr_log: nvidia-vgpu-mgr daemon started
Mar 6 12:20:56 dev1 nvidia-vgpud:
Mar 6 12:20:56 dev1 nvidia-vgpud: Physical GPU:
Mar 6 12:20:56 dev1 nvidia-vgpud: PciID: 0x0000 / 0x0086 / 0x0000 / 0x0000
Mar 6 12:20:56 dev1 nvidia-vgpud: Size: 52#012Version 1
Mar 6 12:20:56 dev1 nvidia-vgpud: DevID: 0x10de / 0x13f2 / 0x10de / 0x0000
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported vGPUs count: 13
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0xb: max 16
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0xb: GRID M60-0B Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x1176
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer: 0x1a000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Mappable video size: 0x400000
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer reservation: 0x6000000
Mar 6 12:20:56 dev1 nvidia-vgpud: FRL configuration: 0x2d
Mar 6 12:20:56 dev1 nvidia-vgpud: CUDA enabled: 0x0
Mar 6 12:20:56 dev1 nvidia-vgpud: Multi vGPU supported: 0x0
Mar 6 12:20:56 dev1 nvidia-vgpud: Encoder Capacity: 0x64
Mar 6 12:20:56 dev1 nvidia-vgpud: BAR1 Length: 0x100
Mar 6 12:20:56 dev1 nvidia-vgpud: Frame Rate Limiter enabled: 0x1
Mar 6 12:20:56 dev1 nvidia-vgpud: Number of Displays: 2
Mar 6 12:20:56 dev1 nvidia-vgpud: Display: width 2560, height 1600
Mar 6 12:20:56 dev1 nvidia-vgpud: License: GRID-Virtual-PC,2.0;GRID-Virtual-WS,2.0;Quadro-Virtual-DWS,5.0;GRID-Virtual-WS-Ext,2.0
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0xc: max 16
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0xc: GRID M60-0Q Class: Quadro
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x114c
Mar 6 12:20:56 dev1 nvidia-vgpud: FRL configuration: 0x3c
Mar 6 12:20:56 dev1 nvidia-vgpud: License: GRID-Virtual-WS,2.0;Quadro-Virtual-DWS,5.0;GRID-Virtual-WS-Ext,2.0
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0xd: max 8
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0xd: GRID M60-1A Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x11ae
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer: 0x38000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer reservation: 0x8000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Number of Displays: 1
Mar 6 12:20:56 dev1 nvidia-vgpud: Display: width 1280, height 1024
Mar 6 12:20:56 dev1 nvidia-vgpud: License: GRID-Virtual-Apps,3.0
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0xe: max 8
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0xe: GRID M60-1B Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x1177
Mar 6 12:20:56 dev1 nvidia-vgpud: Number of Displays: 4
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0xf: max 8
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0xf: GRID M60-1Q Class: Quadro
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x114d
Mar 6 12:20:56 dev1 nvidia-vgpud: Display: width 4096, height 2160
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x10: max 4
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x10: GRID M60-2A Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x11af
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer: 0x74000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer reservation: 0xc000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x11: max 4
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x11: GRID M60-2B Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x117d
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0xd2: max 4
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0xd2: GRID M60-2B4 Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x12ec
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x12: max 4
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x12: GRID M60-2Q Class: Quadro
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x114e
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x13: max 2
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x13: GRID M60-4A Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x11b0
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer: 0xec000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer reservation: 0x14000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x14: max 2
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x14: GRID M60-4Q Class: Quadro
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x114f
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x15: max 1
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x15: GRID M60-8A Class: NVS
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x11b1
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer: 0x1dc000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Framebuffer reservation: 0x24000000
Mar 6 12:20:56 dev1 nvidia-vgpud: Supported VGPU 0x16: max 1
Mar 6 12:20:56 dev1 nvidia-vgpud: VGPU Type 0x16: GRID M60-8Q Class: Quadro
Mar 6 12:20:56 dev1 nvidia-vgpud: DevId: 0x10de / 0x13f2 / 0x10de / 0x1150
Mar 6 12:20:56 dev1 nvidia-vgpud: CUDA enabled: 0x1
Mar 6 12:20:56 dev1 nvidia-vgpud: Multi vGPU supported: 0x1
Mar 6 12:20:56 dev1 kernel: nvidia 0000:86:00.0: MDEV: Registered
Mar 6 12:20:56 dev1 nvidia-vgpud: PciID: 0x0000 / 0x0087 / 0x0000 / 0x0000
Mar 6 12:20:56 dev1 kernel: nvidia 0000:87:00.0: MDEV: Registered
Mar 6 12:20:56 dev1 nvidia-vgpud: PID file unlocked.
Mar 6 12:20:56 dev1 nvidia-vgpud: PID file closed.
Mar 6 12:20:56 dev1 nvidia-vgpud: Shutdown (1562)
However, on each GPU device sysfs entry:
cat /sys/class/mdev_bus/0000:86:00.0/mdev_supported_types/nvidia-*/available_instances
0
0
0
0
0
0
0
0
0
0
0
0
0
cat /sys/class/mdev_bus/0000:87:00.0/mdev_supported_types/nvidia-*/available_instances
16
16
8
8
8
4
4
4
2
2
4
1
1
I have a suspicion this is preventing vGPUs from working in the VMs I have created (both Linux and Windows).
Any idea what could be going on here?
Thnaks for any help,
Cam
