Ldmatrix.x4 with Swizzle<3,3,4> Shows Bank Conflicts When grid > (1,1,1), But Not with grid=(1,1,1) — RTX 3060 (SM86)
I am investigating shared memory bank conflicts when using ldmatrix.sync.aligned.x4.trans (SM75_U16x8_LDSM_T in CuTe) together with a Swizzle<3,3,4> SMEM layout on an RTX 3060 (SM86, Ampere) under Windows 10.
Environment
Item Detail
GPU NVIDIA RTX 3060 12 GB (SM86, Ampere)
OS Windows 10
CUDA Toolkit 12.x
Library CUTLASS / CuTe (latest)
Profiler Nsight Compute
Setup
  • SMEM tile: bM=128, bK=32, element type half (2 bytes)
  • SMEM layout: M-major atom (128, 8):(1, 128), composed with Swizzle<3,3,4>, then tiled to (128, 32)
  • TiledMMA: SM80_16x8x16_F16F16F16F16_TN, warp layout (2M, 2N, 1K), total 128 threads (4 warps) per CTA
  • Copy atom: SM75_U16x8_LDSM_T — i.e., ldmatrix.sync.aligned.x4.trans
  • Swizzle derivation (for half, 128-bit vector):
    • MBase = log2(16B / 2B) = 3
    • BBits = log2(32 × 4 / 2) - 3 = 3
    • SShift = log2(128) - 3 = 4
    • Swizzle<3, 3, 4>
Key kernel + host code:
namespace {
constexpr int constexpr_log2(int n) { return (n <= 1) ? 0 : 1 + constexpr_log2(n / 2); }
}  // namespace
template <typename ASmemLayout, typename SmemTiledCopyA, typename TiledMMA>
__global__ void kernel_ldmatrix(ASmemLayout smem_layout_A, SmemTiledCopyA smem_tiled_copy_A, TiledMMA tiled_mma) {
  using T = cute::half_t;
  __shared__ T smem_A[cute::cosize_v<ASmemLayout>];
  const int total = cute::cosize_v<ASmemLayout>;
  for (int i = threadIdx.x; i < total; i += blockDim.x) {
    smem_A[i] = T(static_cast<float>(i));
  __syncthreads();
  auto tensor_smem_A = cute::make_tensor(cute::make_smem_ptr(smem_A), smem_layout_A);  // (bM=128, bK=32)
  // ---- SMEM -> REG via ldmatrix ----
  auto thr_mma  = tiled_mma.get_slice(threadIdx.x);
  auto mma_tCrA = thr_mma.partition_fragment_A(tensor_smem_A);  // (MMA, MMA_M, MMA_K)
  auto smem_thr_copy_A = smem_tiled_copy_A.get_slice(threadIdx.x);
  auto smem_tCsA       = smem_thr_copy_A.partition_S(tensor_smem_A);  // (CPY, CPY_M, CPY_K)
  auto smem_tCrA_view  = smem_thr_copy_A.retile_D(mma_tCrA);          // (CPY, CPY_M, CPY_K)
  cute::copy(smem_tiled_copy_A, smem_tCsA, smem_tCrA_view);
  if (cute::thread0()) {
    printf("\n=== mma_tCrA values (thread 0, after ldmatrix) ===\n");
    for (int i = 0; i < cute::size(mma_tCrA); i++) {
      printf("  mma_tCrA[%2d] = %.0f\n", i, float(mma_tCrA(i)));
void test_ldmatrix() {
  constexpr int M = 4096, K = 4096;
  // CTA tile:bM=128(M 方向),bK=32(K 方向)
  constexpr auto bM = cute::Int<128>{};
  constexpr auto bK = cute::Int<32>{};
  // ---- Swizzle<BBits, MBase, SShift> 参数推导 ----
  // 与 test_async_cp_ldmatrix.cu 保持一致,消除 ldmatrix 的 SMEM bank conflict
  // MBase = log2(128bit向量宽度 / 元素宽度) = log2(16B / 2B) = 3
  // BBits = log2(bM_in_bytes / vector_bytes) - ... = log2(64) - 3 = 3
  // SShift = log2(bM) - MBase = 7 - 3 = 4
  // 最终 Swizzle<3,3,4>
  constexpr auto MBase_A   = constexpr_log2(sizeof(cute::uint128_t) / sizeof(T));  // 3
  constexpr auto BBits_A   = constexpr_log2(32 * 4 / sizeof(T)) - MBase_A;         // 3
  constexpr auto SShift_A  = constexpr_log2(bM) - MBase_A;                         // 4
  constexpr auto swizzle_A = cute::Swizzle<BBits_A, MBase_A, SShift_A>{};          // Swizzle<3,3,4>
  // SMEM layout:atom=(128M,8K),M-major;叠加 Swizzle 后 tile 到 (128M,32K)
  constexpr auto smem_atom_layout_A          = cute::make_layout(cute::make_shape(bM, cute::Int<8>{}));  // (128,8):(1,128)
  constexpr auto smem_atom_layout_A_swizzled = cute::composition(swizzle_A, smem_atom_layout_A);
  constexpr auto smem_layout_A               = cute::tile_to_shape(smem_atom_layout_A_swizzled, cute::make_shape(bM, bK));
  // ---- TiledMMA:SM80_16x8x16,warp 排布 (2M,2N,1K),mma_tile=(32M,32N,16K) ----
  using MMATraits               = cute::MMA_Traits<cute::SM80_16x8x16_F16F16F16F16_TN>;
  using MMAAtomShape            = MMATraits::Shape_MNK;
  constexpr auto mma_atom       = cute::MMA_Atom<MMATraits>{};
  constexpr auto mma_atom_shape = MMAAtomShape{};
  constexpr int MMA_LAYOUT_M = 2, MMA_LAYOUT_N = 2, MMA_LAYOUT_K = 1;
  constexpr int NUM_MMA_TILE_M = 1, NUM_MMA_TILE_N = 2, NUM_MMA_TILE_K = 1;
  constexpr auto MMA_TILE_M = cute::get<0>(mma_atom_shape) * NUM_MMA_TILE_M * MMA_LAYOUT_M;  // 16*1*2=32
  constexpr auto MMA_TILE_N = cute::get<1>(mma_atom_shape) * NUM_MMA_TILE_N * MMA_LAYOUT_N;  // 8*2*2=32
  constexpr auto MMA_TILE_K = cute::get<2>(mma_atom_shape) * NUM_MMA_TILE_K * MMA_LAYOUT_K;  // 16*1*1=16
  constexpr auto mma_layout =
    cute::make_layout(cute::make_shape(cute::Int<MMA_LAYOUT_M>{}, cute::Int<MMA_LAYOUT_N>{}, cute::Int<MMA_LAYOUT_K>{}));
  constexpr auto mma_tile  = cute::make_tile(cute::Int<MMA_TILE_M>{}, cute::Int<MMA_TILE_N>{}, cute::Int<MMA_TILE_K>{});
  constexpr auto tiled_mma = cute::make_tiled_mma(mma_atom, mma_layout, mma_tile);  // 128 threads
  std::cout << "=== tiled_mma ===\n";
  cute::print(tiled_mma);
  // ---- SMEM -> REG tiled copy via ldmatrix ----
  // SM75_U16x8_LDSM_T = ldmatrix.sync.aligned.x4.trans(转置加载,供 A operand 使用)
  using Copy_Atom_A                = cute::Copy_Atom<cute::SM75_U16x8_LDSM_T, T>;
  constexpr auto smem_tiled_copy_A = cute::make_tiled_copy_A(Copy_Atom_A{}, tiled_mma);
  std::cout << "\n=== smem_tiled_copy_A ===\n";
  cute::print(smem_tiled_copy_A);
  std::cout << "\n";
  // 单个 CTA,128 线程(4 warp),grid=1
  dim3 block(cute::size(tiled_mma));  // 128
  dim3 grid(M / bM, K / bK);
  kernel_ldmatrix<<<grid, block>>>(smem_layout_A, smem_tiled_copy_A, tiled_mma);
  if (cudaError_t err = cudaDeviceSynchronize(); err != cudaSuccess) {
    std::cerr << "CUDA error: " << cudaGetErrorString(err) << std::endl;
int main() {
  test_ldmatrix();
  return 0;
grid(1) (single CTA, same 128-thread block): zero bank conflicts:
grid(32, 128) (or any grid with more than one CTA): bank conflicts are reported on the ldmatrix instruction:
so, the questions are:
  1. Why does the grid dimension affect shared memory bank conflicts within a single CTA? Each CTA has its own independent SMEM, and the access pattern per warp should not change with grid size.
  2. Is Swizzle<3,3,4> the correct choice for ldmatrix.x4.trans with half and bM=128? I derived it following the standard formula; if there is an error in the derivation, I would appreciate a correction.
  3. The atom layout is created the right way ?
it may be a profiler sampling issue. The profiler may collect statistics in a way that causes a single CTA to be misrepresented.
Thank you for your tips @Robert_Crovella . So the main question maybe why this Swizzle<3,3,4> configure for ldmatrix.x4.trans can not dismiss all of the bank confits.
