Lenovo NVIDIA Corporation GA107GLM [RTX A2000 Mobile] (rev a1) Driver & cuda
  • Linux: Ubuntu 24.04.1 LTS
  • Kernel: 6.8.0-40-generic #40-Ubuntu SMP PREEMPT_DYNAMIC Fri Jul 5 10:34:03 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
I have gone for a full day to almost all driver versions.
Some failed to compile some not. Most promising is 535.
Here is a b rief system check after I did:
 1857 sudo apt remove --purge 'nvidia-*'
 1858  sudo apt remove --purge 'nvidia-*'
 1859  sudo apt autoremove
 1860  sudo apt autoclean
 1861  sudo apt install --reinstall linux-headers-$(uname -r)
1862  sudo reboot
 1897  sudo apt install nvidia-driver-550
 1898  sudo apt install nvidia-driver-535
 1899  sudo apt install -y libnvidia-cfg1-535:amd64
 1900  sudo apt install -y libnvidia-common-535
 1901  sudo apt install -y libnvidia-compute-545:amd64
 1902  sudo apt install -y libnvidia-compute-535:amd64
 1903  sudo apt install -y libnvidia-decode-535:amd64
 1904  sudo apt install -y libnvidia-encode-535:amd64
 1905  sudo apt install -y libnvidia-extra-535:amd64
 1906  sudo apt install -y libnvidia-fbc1-535:amd64
 1907  sudo apt install -y libnvidia-gl-535:amd64
 1908  sudo apt install -y nvidia-compute-utils-535
 1909  sudo apt install -y nvidia-dkms-535
 1910  sudo apt install -y nvidia-driver-535
 1912  sudo apt install -y nvidia-kernel-common-535
 1913  sudo apt install -y nvidia-kernel-source-535
 1914  sudo apt install -y nvidia-prime
 1915  sudo apt install -y nvidia-settings
 1916  sudo apt install -y nvidia-utils-535
1917  sudo reboot
 1918  sudo apt install --reinstall linux-headers-$(uname -r)
 1919  sudo reboot
marius@tpp:~$ lsmod | grep nvi
marius@tpp:~$                  ### <<<   EMPTY
marius@tpp:~$ dkms status
nvidia/535.183.01, 6.8.0-40-generic, x86_64: installed
marius@tpp:~$
marius@tpp:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
marius@tpp:~$ sudo nvidia-smi
I really ran out of options. Any help would be appreciated.
Thank you.
All commands were typed over ssh shell into a remote desktop.
nvidia-bug-report.log.gz (177.1 KB)
