Hi SimonZhu!
I want use AR0144 in my TX2 board.
However I follow the Dropbox - File Deleted
, I get some problems.
First I can’t find the tegra186-quill-p3310-1000-c03-00-base.dtb.
7. Copy the tegra186-quill-p3310-1000-c03-00-base.dtb (which was downloaded from the first link above) and replace the tegra186-quill-p3310-1000-c03-00-base.dtb under Linux_for_Tegra/kernel/dtb on your Ubuntu host PC (* Not TX2 *).
Second I patch 6_streaming_ar0144_base_28.2_EVM_tx1_dtbs_20180718.patch file , but get some error, eg can’t find the tegra210-jetson-cv-power-fixed-p2180-p2597-a00.dtsi.
2) Copy kernel_src.tbz2 and two patch files to /usr/src
sudo tar xpf kernel_src-tx2.tbz2
sudo chown -R <user_name> kernel
sudo chown -R <user_name> hardware
patch -p0 < 6_streaming_ar0144_base_28.2_EVM_tx1_dtbs_20180718.patch
patch -p0 < 6_streaming_ar0144_base_28.2_EVM_tx1_kernel_20180718.patchh (patchh or patch ??)
Hi SimonZhu
We are interested in the LI-IMX264-MIPI-M12 camera you are offering. Do you happen to have sample outdoor videos on daylight and nighttime captured with that product? Also, we would like to know if you have tested the frame rate reached on the Jetson TX2 and if it is available for L4T 28.2. Thanks
We are interested in the LI-TX1-CB-6CAM carrier board in combination with a TX2 (not TX1) and either the AR0144 or IMX264 camera. Are drivers available for both combinations (TX2 + LI-TX1-CB-6CAM + AR0144 and TX2 + LI-TX1-CB-6CAM + IMX264)? Do you have sample videos for both cameras?
We have TX1 driver for LI-TX1-CB-6CAM + AR0144 camera kit but don’t have the TX2 driver for 6 x AR0144 or IMX264 yet. You can send a request to our Support Email (support@leopardimaging.com). We will put your Email address in our list and let you know once we get the driver ready.
