When destroying the Argus object, gcc ASAN detects a mismatch with the new / delete operator. It seems that the delete method in this library should be called with delete instead of delete.
==1243460==ERROR: AddressSanitizer: alloc-dealloc-mismatch (operator new [] vs operator delete) on 0xffff9b51c800
#0 0xffffb2ec5678 in operator delete(void*, unsigned long) ../../../../src/libsanitizer/asan/asan_new_delete.cc:177
#1 0xffffa4ad051c (/usr/lib/aarch64-linux-gnu/tegra/libnvscf.so+0x14751c)
#2 0xffffa4ad05e0 (/usr/lib/aarch64-linux-gnu/tegra/libnvscf.so+0x1475e0)
#3 0xffffa49ece94 (/usr/lib/aarch64-linux-gnu/tegra/libnvscf.so+0x63e94)
#4 0xffffb2cf4788 (/usr/lib/aarch64-linux-gnu/tegra/libnvargus.so+0x8d788)
#5 0xaaaae41e4d24 in Argus::UniqueObj<Argus::OutputStream>::reset(Argus::OutputStream*) external/argus_on_device/Argus/Types.h:471
#6 0xaaaae41dac68 in Argus::UniqueObj<Argus::OutputStream>::~UniqueObj() external/argus_on_device/Argus/Types.h:478
0xffff9b51c800 is located 0 bytes inside of 233000-byte region [0xffff9b51c800,0xffff9b555628)
allocated by thread T3 here:
#0 0xffffb2ec4654 in operator new[](unsigned long, std::nothrow_t const&) ../../../../src/libsanitizer/asan/asan_new_delete.cc:113
#1 0xffffa4acf4d8 (/usr/lib/aarch64-linux-gnu/tegra/libnvscf.so+0x1464d8)
This was causing crashing with using tcmalloc library due to being unable to properly deallocate OutputStream. DBG output:
(gdb) bt
#0 0x0000ffffdc471ec8 in ?? () from /lib/libc.so.6
#1 0x0000ffffdc42dd50 in raise () from /lib/libc.so.6
#2 0x0000ffffdc41af64 in abort () from /lib/libc.so.6
#3 0x0000aaaaac527c5c in tcmalloc::tcmalloc_internal::Crash(tcmalloc::tcmalloc_internal::CrashMode, char const*, int, tcmalloc::tcmalloc_internal::LogItem, tcmalloc::tcmalloc_internal::LogItem, tcmalloc::tcmalloc_internal::LogItem, tcmalloc::tcmalloc_internal::LogItem, tcmalloc::tcmalloc_internal::LogItem, tcmalloc::tcmalloc_internal::LogItem) ()
#4 0x0000aaaaac59709c in operator delete(void*, unsigned long) ()
#5 0x0000ffffda9873d0 in scf::EGLStreamProducer::~EGLStreamProducer() () from /usr/lib/libnvscf.so
#6 0x0000ffffda987494 in scf::EGLStreamProducer::~EGLStreamProducer() [clone .localalias] ()
#7 0x0000ffffda8a3e88 in scf::Session::destroyOutputStream(scf::IOutputStream*) () from /usr/lib/libnvscf.so
#8 0x0000fffff7cdd82c in non-virtual thunk to Argus::EGLOutputStreamImpl::destroy() () from /usr/lib/libnvargus.so
#9 0x0000aaaaab0f6888 in Argus::UniqueObj<Argus::OutputStream>::reset(Argus::OutputStream*) ()
#10 0x0000aaaaab0f0044 in Argus::UniqueObj<Argus::OutputStream>::~UniqueObj() ()
