When destroying the Argus object, gcc ASAN detects a mismatch with the new / delete operator, that could lead to heap corruption.
==33325==ERROR: AddressSanitizer: alloc-dealloc-mismatch (operator new [] vs operator delete) on 0xffff8b08b800
#0 0xffffa8a0cacc in operator delete(void*, unsigned long) ../../../../src/libsanitizer/asan/asan_new_delete.cpp:172
#1 0xffffa544a918 (/usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so+0x15a918)
#2 0xffffa544a9e0 (/usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so+0x15a9e0)
#3 0xffffa535dd94 (/usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so+0x6dd94)
#4 0xffffa8893160 (/usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so+0x93160)
#5 0xaaaae44ae0c0 in Argus::UniqueObj<Argus::OutputStream>::reset(Argus::OutputStream*) /usr/src/jetson_multimedia_api/argus/include/Argus/Types.h:486
#6 0xaaaae449a91c in Argus::UniqueObj<Argus::OutputStream>::~UniqueObj() /usr/src/jetson_multimedia_api/argus/include/Argus/Types.h:493
#7 0xaaaae449a91c in main /work/tests/test_argus/main.cpp:84
#8 0xffffa5b073f8 in __libc_start_call_main ../sysdeps/nptl/libc_start_call_main.h:58
#9 0xffffa5b074c8 in __libc_start_main_impl ../csu/libc-start.c:392
#10 0xaaaae4497d2c in _start (/work/tests/test_argus/test_argus+0x7d2c)
0xffff8b08b800 is located 0 bytes inside of 233096-byte region [0xffff8b08b800,0xffff8b0c4688)
allocated by thread T0 here:
#0 0xffffa8a0bf70 in operator new[](unsigned long, std::nothrow_t const&) ../../../../src/libsanitizer/asan/asan_new_delete.cpp:108
#1 0xffffa54498a8 (/usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so+0x1598a8)
#2 0xffffa5b073f8 in __libc_start_call_main ../sysdeps/nptl/libc_start_call_main.h:58
#3 0xffffa5b074c8 in __libc_start_main_impl ../csu/libc-start.c:392
#4 0xaaaae4497d2c in _start (/work/tests/test_argus/test_argus+0x7d2c)
SUMMARY: AddressSanitizer: alloc-dealloc-mismatch ../../../../src/libsanitizer/asan/asan_new_delete.cpp:172 in operator delete(void*, unsigned long)
I made a simple reproductible test code, it needs a camera connected to the Orin:
