Hey there, I’ve been working with the examples in MMAPI and have even had success at adding my own program into the argus/samples and modifying the CMakeLists.txt. However, I would like to be able to write my own example program that uses libargus without all the included overhead of the MMAPI with all it’s samples and nested makefiles.
-Projects
-main.cpp
-Makefile
-jetson_multimedia_api/
I would like to run a really simple sample program that simply uses the API to create a camera provider object, say hello and exit without crashing.
#include <stdio.h>
#include <Argus/Argus.h>
using namespace Argus;
int main() {
UniqueObj<CameraProvider> cameraProvider(CameraProvider::create());
ICameraProvider* iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if(!iCameraProvider)
printf("Failed to generate camera provider\n");
return 1;
printf("Hello world\n");
return 0;
I’ve looked into the gnu make docs about adding directories for the preprocessor to check but I’m getting stuck on figuring out how to apply this to using Argus. I’ve examined the Makefiles and CMakeLists but I haven’t been able to discern what I’m missing. The part that I’m clearly stumped by is how to make the compilation work with
What I’m asking for is help writing a single Makefile to compile and link my example program. Any help and guidance would be greatly appreciated.
