Shipping libcudart.dylib (and libcufft.dylib and libcublas.dylib, if you use them) from the CUDA Toolkit with your application is indeed the correct approach. You should install them into a location relative to your application’s installation directory rather than to any absolute path in the system for exactly the reasons you mentioned.
We suggest linking with these libraries in such a way that the application binary contains references within the application bundle similar to the following:
[font=“Lucida Console”] @executable_path/…/Library/libcudart.dylib
@executable_path/…/Library/libcufft.dylib
…[/font]
You are correct that install_name_tool is the way to set this up, using install_name_tool to change the LC_ID_DYLIB for the libraries to be redistributed. The full process would look like this:
To change this for libcudart.dylib (after copying it to a new location):
[font=“Lucida Console”]> install_name_tool -id “@executable_path/…/Library/libcudart.dylib” libcudart.dylib [/font]
To verify that this worked, use the otool -D command:
[font=“Lucida Console”]> otool -D libcudart.dylib
libcudart.dylib:
@executable_path/…/Library/libcudart.dylib[/font]
When an application is linked with this modified libcudart.dylib (using the appropriate -L and -lcudart options), the resulting binary will contain the reference “@executable_path/…/Library/libcudart.dylib” instead of “@rpath/libcudart.dylib”. The application bundle must of course be constructed to contain the necessary paths to find libcudart.dylib at location you have chosen.
Note: As of CUDA 3.0, libtlshook.dylib must be redistributed alongside libcudart.dylib. Our suggestion is to place it in the same directory as the redistributed libcudart.dylib. libcudart.dylib contains a reference to “@rpath/libtlshook.dylib” and also has an LC_RPATH entry for “@loader_path/”. In this way, it expects to be able to find libtlshook.dylib in the same directory as libcudart.dylib is itself found. The same treatment as above can be applied to libcufft.dylib.
By way of example, let’s assume we have a very simple hello.cu file, and that we’ll compile it to “hello”, which will depend on a copy of libcudart.dylib in the same directory as the executable. For this example, we’ll skip creating a full application bundle, but we’ll at least want to verify that the libcudart.dylib we’re using is the one in the same directory as the hello executable:
[font=“Lucida Console”]> cd
cp /usr/local/cuda/lib/libtlshook.dylib .
cp /usr/local/cuda/lib/libcudart.dylib .
install_name_tool -id “@executable_path/” libcudart.dylib
nvcc -noprof -I/usr/local/cuda/include -L. -lcudart -o hello hello.cu[/font]
Now if we examine the resulting binary, we can see that it contains a dylib load command that refers to the path containing the executable:
[font=“Lucida Console”]> otool -l hello
cmd LC_LOAD_DYLIB
cmdsize 60
name @executable_path/libcudart.dylib (offset 24)
[…][/font]
These instructions came directly from our software team, so if you’ve tried these steps (it sounds like you might have) and they’re still not working for some reason, please let me know. I’d also be interested to know whether you’ve tried it with both CUDA 2.3 and CUDA 3.0.
Thanks,
–Cliff
