I’m having a little problem which is really frustrating me. My installation of CUDA all goes to plan. The examples work great. deviceQuery runs fine, as does bandwidthTest. However when I try to run a program I have written it gives me the error:
dyld: Library not loaded: @rpath/libcudart.dylib
Referenced from : /blah/blah
Reason: image not found
Trace/BPT trap
All my path variables are set up correctly. I have checked. I am compiling simply by nvcc blah.cu -o blah
The same code works on my other machine without problems. What could the problem be here?
When you say “All my path variables are set up correctly”, does that mean DYLD_LIBRARY_PATH includes where the toolkit libraries installed? (should be /usr/local/cuda/lib by default)
Also for big projects mixing c/c++ and cuda I build using the common.mk that the CUDA sdk provides. It is a very nice engine and you can customize it with new flags. It is a great way for building your code. I am surprised that people are not using it as a reference as it is or build from it a new common file.
The installations of all the parts ( Driver, Toolkit, SDK) went fine, but i suppose i failed in " setting my path variables correctly ".
I red about this two commands :
where i should be before executing them?
should i complete theme in some way for my own document tree ?
How can I place them in ~/.bash_profile since I do not have any?
Should i create it ?
Thanks in advance for your help, I’m just a student, but I have been fascinated by this argument and I’d like to practice.
Forgive me for my bad english, but I’m Italian. :D
Yes, just create a file in your home directory called .bash_profile, put the export commands in there then run “source .bash_profile” and you should be up and running.
Stop messing with scripts and “export” commands. Just tell the binary where to look, with install_name_tool. I do, and my CUDA programs (full application bundles) are double-clickable, with no script editing needed (for running it, that is - building is another matter).
Is there an install_name_tool or similar for Linux?
