I have issued “make” command and the deviceQuery example was compiled successfully, Or at least I didn’t see any error.
But when I try to run it by issuing ./deviceQuery
I receive this error
dyld: Library not loaded: @rpath/libcudart.dylib
Referenced from: /Developer/CUDA/bin/darwin/release/./deviceQuery
Reason: image not found
Trace/BPT trap
What should I do? any help is appreciated.
By the way I have a MackBook pro and a Newbie to both mac and CUDA
I have this error when I run it as root. When I add the export DYLD_LIBRARY_PATH command it works for root and my graphics card is recognized. Under the regular user account (even with the .bash_profile modifications), I get the Device Emulation mode for the graphics card. I changed a bunch of priviledges with no succes so far.
Try installing the toolkit again. Make sure you click “Customize” and select the “kext” thingy. It’s unselected by default … and its description is … “It allows you to run CUDA”
Is there any way to handle this without messing with the . bash_profile? If my program doesn’t run from the command-line, that file is meaningless, and there are also cases when you don’t want to mess with the user profile.
