I’m trying to run GitHub - hamdiboukamcha/Yolo-V11-cpp-TensorRT: The YOLOv11 C++ TensorRT Project in C++ and optimized using NVIDIA TensorRT and after some minor code changes get to link stage but it errors out because it can’t find libnvdla_compiler.so:
[100%] Linking CXX executable YOLOv11TRT
/usr/bin/ld: warning: libnvdla_compiler.so, needed by /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addSlice(nvdla::ITensor*, nvdla::Weights, nvdla::Weights, nvdla::Weights, nvdla::Weights, nvdla::SliceLayerMode)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addReshape(nvdla::ITensor*, nvdla::Dims4)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanCompressStructuredSparseWeights(bool)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanGenerateDetailedLayerwiseStats(bool)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::createNetwork()'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanGenerateLayerwiseStats(bool)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addResize(nvdla::ITensor*, nvdla::ResizeMode, nvdla::Weights)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::ISoftMaxLayer::setAxis(int)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IConcatenationLayer::setAxis(int)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::destroyNetwork(nvdla::INetwork*)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::createWisdom()'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addReduce(nvdla::ITensor*, nvdla::PoolingType, nvdla::Weights)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IPoolingLayer::setPoolingPaddingInclusionType(nvdla::PoolingPaddingInclusionType)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::destroyWisdom(nvdla::IWisdom*)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addTranspose(nvdla::ITensor*, nvdla::Dims4)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setUseSoftMaxOptz(bool)'
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/YOLOv11TRT.dir/build.make:269: YOLOv11TRT] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/YOLOv11TRT.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
This is confirmed by running a find search:
jetson@jetson:~/Yolo-V11-cpp-TensorRT$ find /usr -name libnvdla_compiler.so -o -name libnvdla_runtime.so -o -name libnvrm_gpu.so -o -name libnvrm_mem.so
/usr/lib/aarch64-linux-gnu/nvidia/libnvdla_runtime.so
/usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so
/usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so
So I decided to try with docker since there exists nvcr.io/nvidia/l4t-jetpack:r36.4.0.
And I see a similar issue during the docker build command, but this time, it’s missing more libraries: libnvdla_runtime.so, libnvrm_gpu.so and libnvrm_mem.so:
18.81 [100%] Linking CXX executable YOLOv11TRT
18.94 /usr/bin/ld: warning: libnvdla_compiler.so, needed by /usr/lib/aarch64-linux-gnu/libnvinfer.so, not found (try using -rpath or -rpath-link)
19.03 /usr/bin/ld: warning: libnvdla_runtime.so, needed by /usr/local/cuda/compat/libnvcudla.so, not found (try using -rpath or -rpath-link)
19.04 /usr/bin/ld: warning: libnvrm_gpu.so, needed by /usr/local/cuda/compat/libcuda.so, not found (try using -rpath or -rpath-link)
19.04 /usr/bin/ld: warning: libnvrm_mem.so, needed by /usr/local/cuda/compat/libcuda.so, not found (try using -rpath or -rpath-link)
19.28 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2UnbindPmResources'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::getOutputTaskStatisticsDesc(int, NvDlaRuntimeTaskStatisticsDesc*)'
19.28 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setUseSoftMaxOptz(bool)'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmMemMap'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuDeviceCacheControl'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuClockGetDomains'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmMemCacheSyncForDevice'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::createSyncStrideSemaphore(NvDlaSemaphoreRec const*, unsigned int)'
19.28 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuDeviceOpen'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::bindSubmitEvent(int, NvDlaSyncEventType, nvdla::ISync*, int*)'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionSetHwpmContextSwitchMode'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionSetPcSamplingMode'
19.29 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addReshape(nvdla::ITensor*, nvdla::Dims4)'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionGetTimeoutMode'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2ReservePmResource'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionPerfbufMap'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::translateRawStatsToCsv(char const*, float, nvdla::CsvStatisticsContainer&)'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionExec'
19.29 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addSlice(nvdla::ITensor*, nvdla::Weights, nvdla::Weights, nvdla::Weights, nvdla::Weights, nvdla::SliceLayerMode)'
19.29 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuLibGetVersionInfo'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionCreateForChannel'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2RegOpsExec'
19.30 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::destroyNetwork(nvdla::INetwork*)'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionCreateChannelless'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::submit(bool, bool, unsigned int, unsigned int, nvdla::ISync**)'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::bindOutputTaskStatistics(int, NvDlaMemDescRec)'
19.30 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::createWisdom()'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmMemUnmap'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2GetInfo'
19.30 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IConcatenationLayer::setAxis(int)'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuClockCloseAsyncReq'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionClose'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionSetTimeoutMode'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmMemHandleFree'
19.30 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmMemCacheSyncForCpu'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::createSyncSemaphore(NvDlaSemaphoreRec const*)'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuDeviceReadTimeNs'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuDeviceGetInfo'
19.31 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanCompressStructuredSparseWeights(bool)'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuLibListDevices'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2PmaStreamAlloc'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::registerTaskStatistics(NvDlaMemDescRec, NvDlaAccessType)'
19.31 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::destroySync(nvdla::ISync*)'
19.31 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addReduce(nvdla::ITensor*, nvdla::PoolingType, nvdla::Weights)'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuClockWaitAsyncReq'
19.32 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IPoolingLayer::setPoolingPaddingInclusionType(nvdla::PoolingPaddingInclusionType)'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuLibOpen'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::unregisterTaskStatistics(NvDlaMemDescRec)'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::destroyRuntime(nvdla::IRuntime*)'
19.32 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::destroyWisdom(nvdla::IWisdom*)'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::createRuntime()'
19.32 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanGenerateDetailedLayerwiseStats(bool)'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuClockGetPoints'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2BindPmResources'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionSetPowergateMode'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuDeviceClose'
19.32 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuClockSet'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2PmaStreamFree'
19.33 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addTranspose(nvdla::ITensor*, nvdla::Dims4)'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::createSyncSyncpoint(NvDlaFenceRec const*)'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuDeviceGetCpuTimeCorrelationInfo'
19.33 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::createNetwork()'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmMemHandleAllocAttr'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionSetSmpcContextSwitchMode'
19.33 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanGenerateLayerwiseStats(bool)'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2ReleasePmResource'
19.33 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2PmaStreamUpdateState'
19.34 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::getNumOutputTaskStatistics(int*)'
19.34 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2Close'
19.34 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuProfilerV2CreateForDevice'
19.34 /usr/bin/ld: /usr/local/cuda/compat/libcuda.so: undefined reference to `NvRmGpuRegOpsSessionPerfbufUnmap'
19.34 /usr/bin/ld: /usr/local/cuda/compat/libnvcudla.so: undefined reference to `nvdla::IRuntime::appendDiagnosticLoadable(int*)'
19.34 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::ISoftMaxLayer::setAxis(int)'
19.34 /usr/bin/ld: /usr/lib/aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::INetwork::addResize(nvdla::ITensor*, nvdla::ResizeMode, nvdla::Weights)'
19.35 collect2: error: ld returned 1 exit status
19.36 make[2]: *** [CMakeFiles/YOLOv11TRT.dir/build.make:191: YOLOv11TRT] Error 1
19.36 make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/YOLOv11TRT.dir/all] Error 2
19.36 make: *** [Makefile:91: all] Error 2
Interestingly enough, if I remove the make command from docker, docker build ... completes (no error), then docker run ..., I can cd into the build directory, run make and everything links properly and all libraries are found:
jetson@jetson:~/Yolo-V11-cpp-TensorRT$ docker run -it --runtime=nvidia ...
root@jetson:/tmp# find /usr -name libnvdla_compiler.so -o -name libnvdla_runtime.so -o -name libnvrm_gpu.so -o -name libnvrm_mem.so
/usr/lib/aarch64-linux-gnu/nvidia/libnvdla_compiler.so
root@jetson:/tmp# dpkg -S libnvdla_compiler.so
dpkg-query: no path found matching pattern *libnvdla_compiler.so*
I searched and found similar issues:
- Libnvcudla.so not found jetpack 36.3
- [JetPack 6.0 container] ImportError: libnvcudla.so: cannot open shared object file: No such file or directory - #4 by alsozatch
but I’m afraid it doesn’t help in my case, maybe because I’m using Jetpack 6.1 or 6.2?
One thing I noticed is that when in docker, tensorrt seems to be for jp6.1:
root@jetson:/tmp# dpkg -l | grep tensor
ii nvidia-tensorrt 6.1+b123 arm64 NVIDIA TensorRT Meta Package
ii nvidia-tensorrt-dev 6.1+b123 arm64 NVIDIA TensorRT dev Meta Package
ii tensorrt 10.3.0.30-1+cuda12.5 arm64 Meta package for TensorRT
ii tensorrt-libs 10.3.0.30-1+cuda12.5 arm64 Meta package for TensorRT runtime libraries
while on host, it says jp6.2:
jetson@jetson:~ $ dpkg -l | grep tensorrt
ii nvidia-tensorrt 6.2+b77 arm64 NVIDIA TensorRT Meta Package
That wouldn’t explain why libnvdla_compiler.so would be missing anyway.
Anybody has any idea why this is happening and how to fix it?
Thanks,
Alain
