Either the mirror sync does not progress or the expected size is wrong. I get the exact same message every time.
FYI For both amd64 and arm64 (11296 != 36712).
Cross references:
Cross references:
Sorry. This is forum for supporting developer tools CUDA-GDB.
Your topic seems out of our scope.
Please find proper forum.
@veraj Agreed.
But with the current UI and selection method it is almost impossible to find/select the correct category.
Could you – as a Moderator – please tag it properly: Thank you.
I am not sure which forum is related, can you give me more details ?
Index of /compute/cuda/repos/ubuntu2204/x86_64 (Index of /compute/cuda/repos/ubuntu2204/sbsa) does belong to the ‘Developer Tools’ > ‘CUDA Developer Tools’ category.
I have not found a way to select just these two categories without any subcategory.
But let us focus on the problem: Either the mirror sync does not progress or the expected size is wrong for some packages at
Index of /compute/cuda/repos/ubuntu2204/x86_64 contains all CUDA related package, not only CUDA developer tools.
What’s exactly issue you have ?
Command:
apt-get update && apt-get install libxnvctrl0
Output:
Get:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 InRelease [1,581 B]
Get:2 http://security.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy InRelease [270 kB]
Get:4 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 Packages [1,759 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [128 kB]
Get:6 http://security.ubuntu.com/ubuntu jammy-security/restricted amd64 Packages [4,476 kB]
Get:7 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [127 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages [1,792 kB]
Get:9 http://archive.ubuntu.com/ubuntu jammy/multiverse amd64 Packages [266 kB]
Get:10 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages [2,984 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages [17.5 MB]
Get:12 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages [1,246 kB]
Get:13 http://security.ubuntu.com/ubuntu jammy-security/multiverse amd64 Packages [47.7 kB]
Get:14 http://archive.ubuntu.com/ubuntu jammy/restricted amd64 Packages [164 kB]
Get:15 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [4,630 kB]
Get:16 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [1,553 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [3,295 kB]
Get:18 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages [55.7 kB]
Get:19 http://archive.ubuntu.com/ubuntu jammy-backports/universe amd64 Packages [35.2 kB]
Get:20 http://archive.ubuntu.com/ubuntu jammy-backports/main amd64 Packages [83.2 kB]
Fetched 40.5 MB in 3s (11.9 MB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following NEW packages will be installed:
libxnvctrl0
0 upgraded, 1 newly installed, 0 to remove and 51 not upgraded.
Need to get 11.5 kB of archives.
After this operation, 58.4 kB of additional disk space will be used.
Get:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 libxnvctrl0 575.57.08-0ubuntu1 [11.5 kB]
Err:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 libxnvctrl0 575.57.08-0ubuntu1
File has unexpected size (37228 != 11536). Mirror sync in progress? [IP: 92.123.27.105 443]
Hashes of expected file:
- SHA512:55f4e397e7a2e6fd3e58d5ecb907d2b80543d9b777211b41c24e240a776d63a2d3616f394f7ef9482dbb6bdd80b84e5286c114c3bf80cd5261d5b14ca2029e24
- SHA256:9b94d8e44821355239f701b50ca597d0de4dd8d9ca2c8f4f196dac0c376b6722
- SHA1:dfcc4bb86c1b1788f75b4188f95cb5044b7c841c [weak]
- MD5Sum:a3950ec389e79d67666e0db77183483a [weak]
- Filesize:11536 [weak]
E: Failed to fetch https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64/./libxnvctrl0_575.57.08-0ubuntu1_amd64.deb File has unexpected size (37228 != 11536). Mirror sync in progress? [IP: 92.123.27.105 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
And no: --fix-missing
is not a solution.
This is a problem on NVIDIA’s side (package repository).
Moved to “CUDA set up and Installation”
Cross references:
This issue seems to be resolved by now.
At least for package libxnvctrl0
Thank you.
