Hi.
I am having problems when i compile a fortran program. It was working fine, then i needed to reinstall all my system. I installed now kubuntu 13.04, and installed the pgi workstation 12.10 (i have a permanent license for this version) the following message is appearing. I did all it is written at INSTALL.txt.
Can you help ?
thanks
alechand@pcsantos2:~/test$ pgfortran Mol_Dyn.f90
pgi-f95-lin32: LICENSE MANAGER PROBLEM: Failed to checkout license
pgi-f95-lin32: LICENSE MANAGER PROBLEM: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: pgi-f95-lin32
Server name: pcsantos2
License path: /opt/pgi/license.dat:
FLEXnet Licensing error:-15,570. System Error: 115 “Operation now in progress”
For further information, refer to the FLEXnet Licensing documentation,
available at “www.flexerasoftware.com”.
