I manage to install pgi 5.2 on my AMD64 box running Gentoo.
(It required some hacking of the makelocalrc script)
However I get all kinds of link errors when trying to compile programs.
Here is an example (C++):
% gCC -v bench.cpp
/opt/pgi/linux86-64/5.2/bin/pgcpp1 --llalign -Dunix -D__unix -D__unix__ -Dlinux -D__linux -D__linux__ -D__inline__= -D__NO_INLINE_
_ -D__NO_MATH_INLINES -D__x86_64__ -D__LONG_MAX__=9223372036854775807L ‘-D__SIZE_TYPE__=unsigned long int’ ‘-D__PTRDIFF_TYPE__=lon
g int’ -D__THROW= -D__amd64__ -D__PGI -I/opt/pgi/linux86-64/5.2/include/CC -I/opt/pgi/linux86-64/5.2/include -I/usr/local/include
-I/usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.4.3/include -I/usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.4.3/include -I/usr/include -q -o /tm
p/pgCCaaaaamAfax.il bench.cpp
/opt/pgi/linux86-64/5.2/bin/pgcpp2 bench.cpp -opt 1 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 120 0x80000000 -x 59 4 -
y 80 0x1000 -x 138 4 -x 80 0x10800000 -astype 0 -fn bench.cpp -il /tmp/pgCCaaaaamAfax.il -cmdline '+pgCC /tmp/pgCCaaaaamAfax.il -v
’ -asm /tmp/pgCCbaaaamAfay.s
NOTE: your evaluation license will expire in 14 days, 23.7 hours.
For a permanent license, please read the order acknowledgement
that you received. Connect to https://www.pgroup.com/License with
the username and password in the order acknowledgement.
User: xxxxx
Email: xxxxx@xxxxx.xx
Hostid: PGI=xxxxxxxxxxxxxxxxxxx
PGCC/x86 Linux/x86-64 5.2-4: compilation successful
/usr/bin/as /tmp/pgCCbaaaamAfay.s -o /tmp/pgCCcaaaamAfay.o
Action(ReadTIFile(./bench.ti))
/opt/pgi/linux86-64/5.2/bin/pgprelnk -c ‘/usr/bin/nm --print-file-name’ -o,/tmp/pgCCdaaaamAfay.nmout -f I386 -YP,/opt/pgi/linux86-64/5.2/lib:/usr/lib64:/usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.4.3 /tmp/pgCCcaaaamAfay.o -lstd
/usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o /usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.4.3/crtbegin.o -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 /tmp/pgCCcaaaamAfay.o -L/opt/pgi/linux86-64/5.2/lib -L/usr/lib64 -L/usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.4.3 -rpath /opt/pgi/linux86-64/5.2/lib -lstd -lC -lc -lnspgc -lpgc -lm -lgcc -lc -lgcc /usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.4.3/crtend.o /usr/lib64/crtn.o
/tmp/pgCCcaaaamAfay.o(.text+0x231): In function array_test__FPdT1i': : undefined reference to sort__tm__3_Pd__3stdFZ1ZT1_v’
/tmp/pgCCcaaaamAfay.o(.text+0x35b): In function vector_pointer_test__FPdT1i': : undefined reference to sort__tm__3_Pd__3stdFZ1ZT1_v’
/tmp/pgCCcaaaamAfay.o(.text+0x4cb): In function vector_iterator_test__FPdT1i': : undefined reference to sort__tm__3_Pd__3stdFZ1ZT1_v’
and so on)
Any hints would be very much appreciated.
Thanks, Markus.
