Hi:
I am trying to link a C++ code on an Ubuntu linux which does have a large number of template instantiations. If I use g++ (4.2.3) on linux then the code links just fine. Using pgCC 7.2-3 the code gives me the link errors
listed at the botom. Here are the compile and link lines:
mpicxx -g -DMPICH_IGNORE_CXX_SEEK -DMPICH_SKIP_MPICXX -DNDIM=3 -g -DMPICH_IGNORE_CXX_SEEK -DMPICH_SKIP_MPICXX -I. -I/packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/include -I/packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/include -I/packages/petsc/petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/include -I/packages/petsc/petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/include/private -I/packages/hypre/hypre-2.0.0-mpich2-1.0.6p1-pgi-7.2-3-debug/include -I/packages/hdf/hdf5-1.6.7-mpich2-1.0.6p1-pgi-7.2-3-debug/include -I/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/include -DNDIM=3 -I/netscratch/bphilip/projects/utils/include -c testInterpolation.C -o testInterpolation.o
mpicxx -g -DMPICH_IGNORE_CXX_SEEK -DMPICH_SKIP_MPICXX -DNDIM=3 -L/packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/petsc/petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/hypre/hypre-2.0.0-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/hdf/hdf5-1.6.7-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -R /packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/nh/vendor/Linux/pgi/Ubuntu8.04-AMD64/PGI_Server-7.2-3/linux86-64/7.2-3/lib -R /nh/vendor/Linux/pgi/Ubuntu8.04-AMD64/PGI_Server-7.2-3/linux86-64/7.2-3/lib -L/usr/lib64 -R /usr/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.3 -R /usr/lib/gcc/x86_64-linux-gnu/4.2.3 testInterpolation.o BogusTagAndInitStrategy.o
/netscratch/bphilip/projects/utils/lib/libAMRUtils3d.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_appu.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_algs.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_solv.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_geom.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_mesh.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_math_std.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_pdat_std.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_xfer.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_hier.a /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI.a -L/packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/petsc/petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/hypre/hypre-2.0.0-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/hdf/hdf5-1.6.7-mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -R /packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -L/nh/vendor/Linux/pgi/Ubuntu8.04-AMD64/PGI_Server-7.2-3/linux86-64/7.2-3/lib -R /nh/vendor/Linux/pgi/Ubuntu8.04-AMD64/PGI_Server-7.2-3/linux86-64/7.2-3/lib -L/usr/lib64 -R /usr/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.3 -R /usr/lib/gcc/x86_64-linux-gnu/4.2.3 -lpetsccontrib -lpetscksp -lpetscsnes -lpetscdm -lpetscts -lpetscmat -lpetscvec -lpetsc -lHYPRE_sstruct_ls -lHYPRE_sstruct_mv -lHYPRE_struct_ls -lHYPRE_struct_mv -lHYPRE_parcsr_ls -lHYPRE_DistributedMatrixPilutSolver -lHYPRE_ParaSails -lHYPRE_Euclid -lHYPRE_MatrixMatrix -lHYPRE_DistributedMatrix -lHYPRE_IJ_mv -lHYPRE_parcsr_mv -lHYPRE_seq_mv -lHYPRE_krylov -lHYPRE_utilities -lhdf5 -llapack -lblas -lz -ldl -lSM -lICE -lX11 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.3 -L/usr/lib64 -L/nh/vendor/Linux/pgi/Ubuntu8.04-AMD64/PGI_Server-7.2-3/linux86-64/7.2-3/lib -L/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -lmpichf90 -lmpich -lpthread -lrt -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lnspgc -lpgc -lm -lgcc -o testInterpolation
The output of mpicxx -show is:
pgCC -I/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/include -L/packages/mpi/mpich2-1.0.6p1-pgi-7.2-3-debug/lib -lmpichcxx -lmpich -lpthread -lrt
The output of ld -v is:
GNU ld (GNU Binutils for Ubuntu) 2.18.0.20080103
The link errors I get are:
.gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J' referenced in section .data’ of /netscratch/bphilip/projects/utils/lib/libAMRUtils3d.a(RefinementBoundaryInterpolation-template-inst.o): defined in discarded section .gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J' of /netscratch/bphilip/projects/utils/lib/libAMRUtils3d.a(RefinementBoundaryInterpolation-template-inst.o) .gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J’ referenced in section .data' of /netscratch/bphilip/projects/utils/lib/libAMRUtils3d.a(HierarchyBoundaryFragments.o): defined in discarded section .gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J’ of /netscratch/bphilip/projects/utils/lib/libAMRUtils3d.a(HierarchyBoundaryFragments.o)
.gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J' referenced in section .data’ of /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_algs.a(tbox__Pointer-algs__HyperbolicLevelIntegrator-NDIM3.o): defined in discarded section .gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J' of /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_algs.a(tbox__Pointer-algs__HyperbolicLevelIntegrator-NDIM3.o) .gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J’ referenced in section .data' of /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_pdat_std.a(tbox__Pointer-pdat__CellDataFactory-NDIM_double3.o): defined in discarded section .gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J’ of /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_pdat_std.a(tbox__Pointer-pdat__CellDataFactory-NDIM_double3.o)
.gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J' referenced in section .data’ of /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_pdat_std.a(tbox__Pointer-pdat__CellDataFactory-NDIM_int3.o): defined in discarded section `.gnu.linkonce.t.__CPR236__getReverseRotationIdentifier__Q3_6SAMRAI4hier40MultiblockPatchHierarchy__tm__9_XCiL_1_3SFQ4_J33JJ40J36MultiblockPatchHierarchy__tm__5_XZ1Z18RotationIdentifier_QJ90JMRAIJ40JJ104JJ142J’ of /packages/samrai/SAMRAI-v2.3.0-petsc-dev-mpich2-1.0.6p1-pgi-7.2-3-debug/lib/libSAMRAI3d_pdat_std.a(tbox__Pointer-pdat__CellDataFactory-NDIM_int3.o)
I would appreciate your help!
