The first time I installed 1.0 I let the installers uninstall my old version of 0.8. I have since uninstalled and reistalled all of the CUDA software, each time deleting the C:\CUDA folder as well as the Nvidia Corporation folder under Program Files. I’ve even removed all CUDA references in the registry. These link errors are occuring with the new SDK examples so its not a backwards compatability issue and it happens with every project in debug, release, emudebug mode etc. I tried running the command line script to creates the cppIntegration.obj file. I copied the string from my friends PC that when run in the command line makes the nvcc.exe create the file and it generated output in the command prompt as well. When I copied the exact string to my PC I recieved no errors, but also no additional output and no file. Any ideas? Thanks
Thanks for the reply, my custom build step is identical to yours. My environment variables seem to be correct as well and are:
CUDA_BIN_PATH C:\CUDA\bin
CUDA_INC_PATH C:\CUDA\include
CUDA_LIB_PATH C:\CUDA\lib
I’ve successfully installed Cuda 1.0 on my home pc as well as a co-workers, but neither of those PC’s had a previous version of Cuda. The only thing I can think of is a path or file thats not being removed when I unistall cuda, delete the folders, edit the registry and remove listings with Cuda, and unistall visual studio 2005 and delete its folder as well. Any more ideas?
I can’t offer much help, but I have also gotten linking errors after upgrading to CUDA 1.0 from CUDA 0.8. Are there lots of other people with this problem? I still have not gotten the new SDK examples to work. I’ll post if I figure anything out.
I have just downloaded the 1.0 SDK and some examples get compilation errors. It seems that they don’t find “glu.h” and “gl.h” in the “common\inc\GL” directory.
I have replaced this files with some of my own, don’t ask me where I have got them. But it still show compilation errors.
LINK : fatal error LNK1104: cannot open file ‘winmm.lib’
There is a winmm.dll library in the windows sys directory, but cuda is looking for the static one.
I have just upgraded to Cuda 1.1 and have the exact same problem. I unistalled all of the previous 1.0 stuff and made sure to delete the orignal folders. I then installed 1.1 i the order specified, but I still get the same error. Has anyone since come across this? Thanks
You correct that the file is not being physically generated. I can even switch the output folder to be something known like c:\ and it never appears there.
