Updates-----
Thanks for the very prompt comments.
I spent all day yesterday chasing this problem… After looking at the compiler output I noticed the following line… (separated by * below)
nvcc -I. -I/opt/cuda/include -D__USE_GPU__ -arch=sm_20 -Xptxas=-v -L/opt/cuda/lib64 -lm -lz -lcuda -lcudart GMRES.o QEq.o allocate.o analyze.o bond_orders.o box.o forces.o four_body_interactions.o grid.o init_md.o integrate.o list.o lookup.o neighbors.o param.o pdb_tools.o print_utils.o reset_utils.o restart.o single_body_interactions.o system_props.o three_body_interactions.o traj.o two_body_interactions.o vector.o testmd.o cuda_utils.o cuda_copy.o cuda_init.o reduction.o center_mass.o helpers.o validation.o matrix.o matvec.o -o GPUReax
In file included from /opt/cuda/bin/crt/link.stub:79:0:(*) /tmp/tmpxft_0000345f_00000000-1_GPUReax_dlink.reg.c:2:1: error: redefinition of ‘const unsigned char def_module_id_str__NV_MODULE_ID ’ /tmp/tmpxft_0000345f_00000000-1_GPUReax_dlink.reg.c:1:1: error: ‘const unsigned char def_module_id_str__NV_MODULE_ID [19]’ previously defined here
Error is coming from the file link.stub file, which is new in the CUDA 5.0 installation. This file was not present in the CUDA 4.2 installation.
If this helps someone pin point the problem.
Thanks for the help.
Sudhir Kylasa
Makefile
CC = g++
NVCC = nvcc
LIBS = -L/opt/cuda/lib64 -lm -lz -lcuda -lcudart
CFLAGS = -I. -Wall -O3 -funroll-loops -fstrict-aliasing
NVCCFLAGS = -I. -I/opt/cuda/include -D__USE_GPU__ -arch=sm_20 -Xptxas=-v
#-finline-functions -finline-limit=15 -g#-DTEST -pg -ldl -rdynamic -g
DEFS = $(CFLAGS)
NVCCDEFS = $(NVCCFLAGS)
FLAG = $(DEFS) $(INCS) $(LIBS)
NVCCFLAG = $(NVCCDEFS) $(LIBS)
OBJ = GMRES.o QEq.o allocate.o analyze.o bond_orders.o
testmd.o
all: beta
beta: $(OBJ) Makefile
$(NVCC) $(NVCCFLAG) $(OBJ) -o GPUReax
param.o: param.c param.h mytypes.h traj.o
$(CC) $(DEFS) -c param.c
traj.o: traj.c traj.h mytypes.h
$(CC) $(DEFS) -c traj.c
restart.o: restart.c restart.h mytypes.h box.h
$(CC) $(DEFS) -c restart.c
pdb_tools.o: pdb_tools.c pdb_tools.h mytypes.h box.h list.h restart.h param.h
$(CC) $(DEFS) -c pdb_tools.c
print_utils.o: print_utils.h print_utils.c
$(CC) $(DEFS) -c print_utils.c
grid.o: grid.h grid.c
$(CC) $(DEFS) -c grid.c
analyze.o: analyze.h analyze.c
$(CC) $(DEFS) -c analyze.c
integrate.o: integrate.h integrate.c
$(CC) $(DEFS) -c integrate.c
vector.o: vector.h vector.cu
$(NVCC) $(NVCCDEFS) -c vector.cu
system_props.o: system_props.h system_props.cu
$(NVCC) $(NVCCDEFS) -c system_props.cu
cuda_copy.o: cuda_copy.h cuda_copy.cu
$(NVCC) $(NVCCDEFS) -c cuda_copy.cu
cuda_utils.o: cuda_utils.h cuda_utils.cu
$(NVCC) $(NVCCDEFS) -c cuda_utils.cu
cuda_init.o: cuda_init.h cuda_init.cu
$(NVCC) $(NVCCDEFS) -c cuda_init.cu
reduction.o: reduction.h reduction.cu
$(NVCC) $(NVCCDEFS) -c reduction.cu
center_mass.o: center_mass.h center_mass.cu
$(NVCC) $(NVCCDEFS) -c center_mass.cu
box.o: box.h
$(NVCC) $(NVCCDEFS) -c box.cu
init_md.o: init_md.h init_md.cu
$(NVCC) $(NVCCDEFS) -c init_md.cu
helpers.o: helpers.h helpers.cu
$(NVCC) $(NVCCDEFS) -c helpers.cu
GMRES.o: GMRES.h GMRES.cu
$(NVCC) $(NVCCDEFS) -c GMRES.cu
neighbors.o: neighbors.cu neighbors.h
$(NVCC) $(NVCCDEFS) -c neighbors.cu
reset_utils.o: reset_utils.h reset_utils.cu mytypes.h list.h vector.h
$(NVCC) $(NVCCDEFS) -c reset_utils.cu
list.o: list.h
$(NVCC) $(NVCCDEFS) -c list.cu
forces.o: forces.h forces.cu
$(NVCC) $(NVCCDEFS) -c forces.cu
allocate.o: allocate.h allocate.cu
$(NVCC) $(NVCCDEFS) -c allocate.cu
lookup.o: lookup.h lookup.cu
$(NVCC) $(NVCCDEFS) -c lookup.cu
two_body_interactions.o: two_body_interactions.h two_body_interactions.cu
$(NVCC) $(NVCCDEFS) -c two_body_interactions.cu
bond_orders.o: bond_orders.h bond_orders.cu
$(NVCC) $(NVCCDEFS) -c bond_orders.cu
single_body_interactions.o: single_body_interactions.h single_body_interactions.cu
$(NVCC) $(NVCCDEFS) -c single_body_interactions.cu
three_body_interactions.o: three_body_interactions.h three_body_interactions.cu
$(NVCC) $(NVCCDEFS) -c three_body_interactions.cu
four_body_interactions.o: four_body_interactions.h four_body_interactions.cu
$(NVCC) $(NVCCDEFS) -c four_body_interactions.cu
validation.o: validation.h validation.cu
$(NVCC) $(NVCCDEFS) -c validation.cu
matrix.o: matrix.h matrix.cu
$(NVCC) $(NVCCDEFS) -c matrix.cu
QEq.o: QEq.h QEq.cu
$(NVCC) $(NVCCDEFS) -c QEq.cu
matvec.o: matvec.h matvec.cu
$(NVCC) $(NVCCDEFS) -c matvec.cu
testmd.o: testmd.cu mytypes.h param.o traj.o restart.o pdb_tools.o list.o vector.o
$(NVCC) $(NVCCDEFS) -c testmd.cu
clean:
rm -f *.o *~ core
