Linking MKL with pgfortran
I’m trying to work one of the example files in MKL, namely pardiso_sym_f90.f90. I obtained a c makefile from someone else, modified it for Intel fortran compiler. I am able to get this code working with that. To use the pgi compiler, I only changed the ifort command to pgfortran. The current makefile I’m using is:
#Define executable
EXEC := exp
#Define constant
RM := rm -f
#Define directories
SRCDIR := ./
HDRDIR :=
SRCEXT := f90
#Define directories    for object and dependency files
OBJDIR := .o
DEPDIR = .d
#Generate source files list
SRCS := $(wildcard $(SRCDIR)/*.$(SRCEXT))
#Generate object and dependency files
OBJS := $(patsubst %,$(OBJDIR)/%.o,$(basename $(SRCS)))
DEPS := $(patsubst %,$(DEPDIR)/%.d,$(basename $(SRCS)))
$(shell mkdir -p $(dir $(OBJS)) >/dev/null)
$(shell mkdir -p $(dir $(DEPS)) >/dev/null)
#Define compiler and library flags
FC := pgfortran
LD := pgfortran
FFLAGS := -warn all -O2 -i8 -I${MKLROOT}/include
LDFLAGS := -L${MKLROOT}/lib/intel64
LDLIBS = -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread -lm -ldl
#Define dependencies
DEPFLAGS = -MT $@ -MMD -MP -MF $(DEPDIR)/$*.Td
#Define compiling and linking commands
COMPILE.f90 = $(FC) $(DEPFLAGS) $(FFLAGS) $(TARGET_ARCH) -c -o $@
LINK.o = $(LD) $(LDFLAGS) $(TARGET_ARCH) -o $@
POSTCOMPILE = mv -f $(DEPDIR)/$*.Td $(DEPDIR)/$*.d
#Define rules
all: $(EXEC)
.PHONY: clean
clean:
	$(RM) -r $(OBJDIR) $(DEPDIR)
.PHONY: distclean
distclean: clean
	$(RM) $(EXEC)
$(EXEC): $(OBJS)
	#$(LD) $(LDFLAGS) $(TARGET_ARCH) -o $@ $^ $(LDLIBS)
	$(LINK.o) $^ $(LDLIBS)
$(OBJDIR)/%.o: %.f90
$(OBJDIR)/%.o: %.f90 $(DEPDIR)/%.d
	$(COMPILE.f90) $<
	$(POSTCOMPILE)
.PRECIOUS: $(DEPDIR)/%.d
$(DEPDIR)/%.d: ;
-include $(DEPS)
The error I get:
pgfortran -MT .o/.//pardiso_sym_f90.o -MMD -MP -MF .d/.//pardiso_sym_f90.Td -warn all -O2 -i8 -I/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include -c -o .o/.//pardiso_sym_f90.o pardiso_sym_f90.f90
pgfortran-Error-Unknown switch: -MT
pgfortran-Error-Unknown switch: -MMD
pgfortran-Error-Unknown switch: -MP
pgfortran-Error-Unknown switch: -MF
pgfortran-Error-Unknown switch: -warn
Makefile:97: recipe for target ‘.o/.//pardiso_sym_f90.o’ failed
make: *** [.o/.//pardiso_sym_f90.o] Error 1
When I close the unknown switches; makefile becomes:
#Define executable
EXEC := exp
#Define constant
RM := rm -f
#Define directories
SRCDIR := ./
HDRDIR :=
SRCEXT := f90
OBJDIR := .o
DEPDIR = .d
FC := pgfortran
LD := pgfortran
#FFLAGS := -warn all -O2 -i8 -I${MKLROOT}/include
#DEPFLAGS = -MT $@ -MMD -MP -MF $(DEPDIR)/$*.Td
#Define rules
all: $(EXEC)
.PHONY: clean
clean:
.PHONY: distclean
distclean: clean
	$(RM) $(EXEC)
$(EXEC): $(OBJS)
	$(COMPILE.f90) $<
	$(POSTCOMPILE)
$(DEPDIR)/%.d: ;
-include $(DEPS)
The error I get:
pgfortran -c -o .o/.//pardiso_sym_f90.o pardiso_sym_f90.f90
PGF90-S-0017-Unable to open include file: mkl_pardiso.f90 (pardiso_sym_f90.f90: 22)
PGF90-F-0004-Unable to open MODULE file mkl_pardiso.mod (pardiso_sym_f90.f90: 24)
PGF90/x86-64 Linux 18.10-1: compilation aborted
make: *** [.o/.//pardiso_sym_f90.o] Error 2
I’m fairly new to makefile concept, any help with this specific problem or in general is appreciated.
Thank you in advance.
Hi kkb,
The problem here is that the compiler doesn’t can’t find the include file.
To fix, update you’re make file with the path to the file.
FFLAGS := -O2 -i8 -I${MKLROOT}/include
Hope this helps,
Mat
Thanks Mat.
With your suggestion, I’m able to create the module files mkl_pardio.mod and mkl_pardiso_private.mod. However, now I’m faced with this result.
pgfortran -O2 -i8 -I/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include -c -o .o/.//pardiso_sym_f90.o pardiso_sym_f90.f90
PGF90-W-0155-END statement for internal procedure should be END FUNCTION (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 485)
PGF90-W-0155-END statement for internal procedure should be END SUBROUTINE (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 496)
PGF90-W-0155-END statement for internal procedure should be END SUBROUTINE (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 504)
PGF90-W-0155-END statement for internal procedure should be END SUBROUTINE (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 518)
PGF90-W-0155-END statement for internal procedure should be END SUBROUTINE (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 528)
PGF90-W-0155-END statement for internal procedure should be END SUBROUTINE (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 538)
PGF90-W-0155-END statement for internal procedure should be END SUBROUTINE (/home/kaan/intel/compilers_and_libraries_2019.3.199/linux/mkl/include/mkl_pardiso.f90: 548)
0 inform, 7 warnings, 0 severes, 0 fatal for mkl_pardiso
mv -f .d/.//pardiso_sym_f90.Td .d/.//pardiso_sym_f90.d
mv: cannot stat ‘.d/.//pardiso_sym_f90.Td’: No such file or directory
Makefile:98: recipe for target ‘.o/.//pardiso_sym_f90.o’ failed
I think my mistake is that I’m trying to create the dependencies automatically, but because of the wrong flag options I’m faced with errors. What else can I fix or are there any suggestions?
Thanks in advance.
We do have some flags for creating makefile dependencies. If you do pgfortran -help, you will see things like -Mcpp[=m|md|mm…] You should see if those map to what you were using with ifort.
