Linux 3.6.x - hybrid suspend
Hi, I have laptop dell e6410 and I cant suspend to ram (s3) and hibernate to disk (S4). But when I enable hybrid suspend/hibernate I can resume computer from hibernation(when computer in the middle time will lose power) But I cant resume computer from suspend(when computer will not lose power in the middle time).
So.
resume from suspend S3 → work
resume from hibernate S4 → work
resume from hibernate (hybrid) → work
resume from suspend (hybrid) → not work, I can login remote to ssh console and I see that X server hang and very often have flags Ds (not interruptible).
I tested It on 3.6.x, driver 304.xx and 310.14.
PS. I cant attach log.gz. Please rename file with log and remove “.jpg”
Thanks for reporting this issue. Is hybrid-suspend supported on your system? Please try command pm-is-supported --suspend-hybrid ; echo $? if output is 0 =supported, 1 =notsupported . Reference : http://manpages.ubuntu.com/manpages/gutsy/man1/pm-is-supported.1.html . Is issue reproduce with open source driver nouveau ? Its good to first report issue on Arch Linux for root cause investigation. If root cause pointing to nvidia driver we will have a look.
It work but without X server resume.
I’ll test with nouveau.
“Its good to first report issue on Arch Linux for root cause investigation.”
I tested it on my own kernel 3.6.x (vanilla) and on kernel from distribution. And using native /proc and /sys interface without pm-tools too. So It is problem in kernel or in NV driver.
f.ex.:
echo suspend > /sys/power/disk
cat /sys/power/disk
platform shutdown reboot [suspend]
echo disk > /sys/power/state
ps.
0
best regards,
I dont have any problem on nouveau, Only on Nvidia drivers. Can you inform us when you will investigate it? :)
wodor, Thanks for this information. Please provide below information :
  • Desktop Environment you are using like KDE, GNOME, Unity etc…
  • Window Manager you are using Compiz, gnome-shell, Kwin, Unity etc…
  • Using any display manager like gdm, kdm etc…
I tested on many environments:
on : lxdm / xfce / compiz / pm-utils
on : lxdm / xfce / compiz / /sys/power/…
on : lxdm / xfce / xfwm4 / pm-utils
on : lxdm / xfce / xfwm4 / /sys/power/…
on : lxdm / fluxbox / /sys/power/…
on : commands : X && DISPLAY=:0 xterm & / echo disk > /sys/power/state (without any desktop environment and window manager)
Always I had that same issue.
additionally to boot scripts I added line which enabled hybrid suspend:
best regards,
ps. Will you investigate it ?
hi, did you get it as a bug? Are you going to work on it?
best regards,
I have that same with 310.19.
best regards,
wodor, I tried to reproduce this issue with Dell E6410 on Ubuntu 12.10
l + kernel 3.6.6-030606-generic + 310.19 driver but no repro .
http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.6.6-raring/
Hm, interesting, Can you supply nvidia-bug-report.log.gz ? I’ll check what is wrong with my configuration … or not
Best regards,
I still have this problem on driver 313.09 and kernels: 3.6.x and 3.7.
Hi, I still have this problem on driver up to 313.18 and kernel up to 3.8 and 3.7. I don’t have idea what is wrong. PS. sandipt: Can you check it on vanilla kernel ?
I compiled 3.6.6 vanilla kernel with config from kernel v3.6.6-raring and problem still occur.
