Hi!
I am trying to install proprietary nvidia drivers without success, tried the Driver Manager, directly installing from binary.
Actual outputs below, preceeded by removing all nvidia drivers, updating the system and using Driver Manager:
apt-get remove nvidia --purge
apt-get autoremove
apt-get autoclean
apt-get update
apt-get upgrade
reboot
nouveau driver successfully loaded
install 525 driver via Driver Manager
Issue:
Driver manager shows installed driver 525:
Although no driver module loaded.
lspci -k | grep 3D -A3
02:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX150] (rev a1)
DeviceName: Second VGA
Subsystem: ASUSTeK Computer Inc. GP108M [GeForce MX150]
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
nvidia-bug-report:
nvidia-bug-report.log.gz (122.3 KB)
Further info:
Secure boot disabled
Dual boot via Grub (Windows + Linux)
External monitor on HDMI
Please advise if I can make the driver work.
T.
generix
February 9, 2023, 10:43pm
2
Please run
sudo modprobe nvidia
and post any errors displayed.
modprobe: ERROR: could not insert ‘nvidia’: Exec format error
generix
February 9, 2023, 10:52pm
4
There seems to be something wrong with your build system/kernel headers so the modules are broken.
Please try uninstalling the nvidia driver, then reinstalling kernel headers
sudo apt install --reinstall linux-headers-$(uname -r)
and reinstall the nvidia driver.
Please post the output of
cc -v
and
ld -v
I have removed the nvidia drivers and tried to reinstall the headers, got the following error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/2.802 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 729285 files and directories currently installed.)
Preparing to unpack .../linux-headers-5.15.0-60-generic_5.15.0-60.66~20.04.1_amd64.deb ...
Unpacking linux-headers-5.15.0-60-generic (5.15.0-60.66~20.04.1) over (5.15.0-60.66~20.04.1) ...
Setting up linux-headers-5.15.0-60-generic (5.15.0-60.66~20.04.1) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 5.15.0-60-generic
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j8 KERNELRELEASE=5.15.0-60-generic KVERSION=5.15.0-60-generic....(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.15.0-60-generic (x86_64)
Consult /var/lib/dkms/rts_pstor/1.11/build/make.log for more information.
...done.
I have added the referenced make.log file:
make.log (1.3 KB)
Did not reinstall the nvidia-drivers, please let me know if I still should with this error.
Output of cc-v:
Using built-in specs.
COLLECT_GCC=cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/9/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:hsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 9.4.0-1ubuntu1~20.04.1' --with-bugurl=file:///usr/share/doc/gcc-9/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,gm2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-9 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-9-Av3uEd/gcc-9-9.4.0/debian/tmp-nvptx/usr,hsa --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)
Output of ld -v:
GNU ld (GNU Binutils for Ubuntu) 2.34
T.
generix
February 9, 2023, 11:10pm
6
You have the rts_pstor driver for realtek cardreaders installed. That’s quite broken and has been an issue before. Please uninstall, then try again reinstalling the headers.
Ok, one step ahead, headers reinstalled successfully. Also installed the nvidia drivers, kernel driver is loaded.
Kernel driver in use: nvidia
However nvidia-smi still throws an error:
Failed to initialize NVML: Driver/library version mismatch
cat Xorg.0.log | grep nvidia
[ 13.312] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[ 13.338] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 13.338] loading driver: nvidia
[ 13.509] (==) Matched nvidia as autoconfigured driver 0
[ 13.509] (II) LoadModule: "nvidia"
[ 13.509] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[ 13.519] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 14.032] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 14.032] (II) Loading sub module "glxserver_nvidia"
[ 14.032] (II) LoadModule: "glxserver_nvidia"
[ 14.032] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
[ 14.093] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 14.479] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
generix
February 9, 2023, 11:37pm
8
Might be some leftover libraries from the runfile install you did at a previous time. Please post the output of
ls -l /usr/lib/x86_64-linux-gnu/libnvidia* /usr/lib/x86_64-linux-gnu/libcuda*
Yep, that will be the problem: 525.78.01 and 525.85.12 is mixed. How could I clean that out?
lrwxrwxrwx 1 root root 28 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libcudadebugger.so.1 -> libcudadebugger.so.525.78.01
-rw-r--r-- 1 root root 10490248 dec 26 06:36 /usr/lib/x86_64-linux-gnu/libcudadebugger.so.525.78.01
lrwxrwxrwx 1 root root 12 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libcuda.so -> libcuda.so.1
lrwxrwxrwx 1 root root 20 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libcuda.so.1 -> libcuda.so.525.85.12
-rw-r--r-- 1 root root 29826984 dec 26 07:06 /usr/lib/x86_64-linux-gnu/libcuda.so.525.78.01
-rw-r--r-- 1 root root 29863848 jan 28 03:21 /usr/lib/x86_64-linux-gnu/libcuda.so.525.85.12
lrwxrwxrwx 1 root root 24 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so -> libnvidia-allocator.so.1
lrwxrwxrwx 1 root root 32 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.1 -> libnvidia-allocator.so.525.85.12
-rw-r--r-- 1 root root 152120 dec 26 06:37 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.525.78.01
-rw-r--r-- 1 root root 152120 jan 28 03:01 /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.525.85.12
lrwxrwxrwx 1 root root 18 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so -> libnvidia-cfg.so.1
lrwxrwxrwx 1 root root 26 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.1 -> libnvidia-cfg.so.525.85.12
-rw-r--r-- 1 root root 258416 dec 26 06:37 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.525.78.01
-rw-r--r-- 1 root root 258416 jan 28 03:01 /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.525.85.12
-rw-r--r-- 1 root root 56309912 dec 26 07:14 /usr/lib/x86_64-linux-gnu/libnvidia-compiler.so.525.78.01
-rw-r--r-- 1 root root 56309912 jan 28 03:30 /usr/lib/x86_64-linux-gnu/libnvidia-compiler.so.525.85.12
-rw-r--r-- 1 root root 42054840 dec 26 07:08 /usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.525.78.01
-rw-r--r-- 1 root root 42054840 jan 28 03:33 /usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.525.85.12
lrwxrwxrwx 1 root root 26 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-egl-gbm.so.1 -> libnvidia-egl-gbm.so.1.1.0
-rw-r--r-- 1 root root 22656 dec 26 06:40 /usr/lib/x86_64-linux-gnu/libnvidia-egl-gbm.so.1.1.0
lrwxrwxrwx 1 root root 21 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so -> libnvidia-encode.so.1
lrwxrwxrwx 1 root root 29 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1 -> libnvidia-encode.so.525.85.12
-rw-r--r-- 1 root root 198720 dec 26 06:38 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.525.78.01
-rw-r--r-- 1 root root 198720 jan 28 03:01 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.525.85.12
lrwxrwxrwx 1 root root 18 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so -> libnvidia-fbc.so.1
lrwxrwxrwx 1 root root 26 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.1 -> libnvidia-fbc.so.525.85.12
-rw-r--r-- 1 root root 133816 dec 26 06:37 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.525.78.01
-rw-r--r-- 1 root root 133816 jan 28 03:01 /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.525.85.12
-rw-r--r-- 1 root root 44278520 dec 26 07:15 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.525.78.01
-rw-r--r-- 1 root root 44282616 jan 28 03:39 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.525.85.12
-rw-r--r-- 1 root root 648136 dec 26 06:38 /usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.525.78.01
-rw-r--r-- 1 root root 648136 jan 28 03:02 /usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.525.85.12
-rw-r--r-- 1 root root 25052888 dec 26 07:19 /usr/lib/x86_64-linux-gnu/libnvidia-glvkspirv.so.525.78.01
-rw-r--r-- 1 root root 25056984 jan 28 03:40 /usr/lib/x86_64-linux-gnu/libnvidia-glvkspirv.so.525.85.12
lrwxrwxrwx 1 root root 17 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so -> libnvidia-ml.so.1
lrwxrwxrwx 1 root root 25 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.1 -> libnvidia-ml.so.525.85.12
-rw-r--r-- 1 root root 1798712 dec 26 06:39 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.525.78.01
-rw-r--r-- 1 root root 1798712 jan 28 03:02 /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.525.85.12
lrwxrwxrwx 1 root root 26 febr 8 02:08 /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.1 -> libnvidia-ngx.so.525.85.12
-rw-r--r-- 1 root root 3310152 dec 26 06:39 /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.525.78.01
-rw-r--r-- 1 root root 3310216 jan 28 03:02 /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.525.85.12
lrwxrwxrwx 1 root root 19 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so -> libnvidia-nvvm.so.4
lrwxrwxrwx 1 root root 27 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.4 -> libnvidia-nvvm.so.525.85.12
-rw-r--r-- 1 root root 92209888 dec 26 07:34 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.525.78.01
-rw-r--r-- 1 root root 92209888 jan 28 03:52 /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.525.85.12
lrwxrwxrwx 1 root root 29 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.1 -> libnvidia-opencl.so.525.85.12
-rw-r--r-- 1 root root 22950352 dec 26 07:06 /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.525.78.01
-rw-r--r-- 1 root root 22991312 jan 28 03:22 /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.525.85.12
lrwxrwxrwx 1 root root 26 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so -> libnvidia-opticalflow.so.1
lrwxrwxrwx 1 root root 34 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.1 -> libnvidia-opticalflow.so.525.85.12
-rw-r--r-- 1 root root 67584 dec 26 06:39 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.525.78.01
-rw-r--r-- 1 root root 67584 jan 28 03:01 /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.525.85.12
lrwxrwxrwx 1 root root 29 jan 4 17:52 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so -> libnvidia-ptxjitcompiler.so.1
lrwxrwxrwx 1 root root 37 febr 10 00:19 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.1 -> libnvidia-ptxjitcompiler.so.525.85.12
-rw-r--r-- 1 root root 20723096 dec 26 06:53 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.525.78.01
-rw-r--r-- 1 root root 20727192 jan 28 03:13 /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.525.85.12
-rw-r--r-- 1 root root 118072320 dec 26 07:32 /usr/lib/x86_64-linux-gnu/libnvidia-rtcore.so.525.78.01
-rw-r--r-- 1 root root 118076416 jan 28 03:54 /usr/lib/x86_64-linux-gnu/libnvidia-rtcore.so.525.85.12
-rw-r--r-- 1 root root 18528 dec 26 06:37 /usr/lib/x86_64-linux-gnu/libnvidia-tls.so.525.78.01
-rw-r--r-- 1 root root 18528 jan 28 03:00 /usr/lib/x86_64-linux-gnu/libnvidia-tls.so.525.85.12
generix
February 9, 2023, 11:47pm
10
That’s quite odd 525.85.12 is not a normal graphics driver, where did you install it from? A cuda runfile?
generix
February 9, 2023, 11:53pm
12
Ok, then please only extract the cuda runfile by running it with -x option. In the directory that will be created, there should be the 525.85.12 driver runfile.
First, please uninstall the packaged driver, then run the 525.85.12 driver runfile with -b option and immediately afterwards again with --uninstall option.
Check
that no nvidia files are installed anymore, then reinstall the packaged driver.
It worked!
Thank you very much for your help and support cleaning up the mess I stumbled together!
T.
