Release highlights since 381.22:
  • Added support for the following GPUs:
    • GeForce GTX 1080 with Max-Q Design
    • GeForce GTX 1070 with Max-Q Design
    • GeForce GTX 1060 with Max-Q Design
    • GeForce GT 1030
    • GeForce MX150
    • P106-100
  • Fixed a bug that could cause OpenGL applications to crash after calling glDeleteBuffers on VBOs that have been remapped with ARB_vertex_attrib_binding.
  • Fixed a bug that could sometimes cause OpenGL applications to lock up until the X server receives input.
  • Fixed a bug that caused nvidia-settings to drop device BusID values when making changes to an existing X configuration file.
  • Fixed a regression that prevented nvidia-xconfig from querying some GPUs, e.g. when running `nvidia-xconfig -a`.
  • Fixed a bug that caused VDPAU playback to be corrupted when extended to coordinates beyond 16384 pixels.
  • Updated nvidia-persistenced to initialize nvidia-modeset.ko in addition to nvidia.ko when setting persistence mode.
  • Restored several sanity checks that were inadvertently removed from the kernel module build process in the 355.06 driver.
  • Added support for a "Nearest" transform filter in the X driver. This causes the X driver to use nearest neighbor filtering when performing screen transformations. The filter can be requested through the 'filter' argument to RandR's RRSetCrtcTransform, or through the 'ResamplingMethod' MetaMode token.
  • Fixed a bug where nvidia-installer would install a wrong version of the Vulkan ICD configuration file when GLVND is disabled for the GLX client.
  • Fixed a bug that could cause driver errors when setting modes on X screens running at Depth 8 or Depth 15.
  • Fixed a bug that could cause intermittent kernel panics when running with PRIME Sync.
  • Fixed a bug that caused a kernel panic when hotplugging HDMI displays on some Zotac mini PCs.
  • Updated nvidia-installer to label kernel modules with SELinux file type 'modules_object_t'. Some system SELinux policies only permit loading of kernel modules with this SELinux file type.
  • Removed support for checking for and downloading updated driver packages and precompiled kernel interfaces from nvidia-installer. This functionality was limited to unencrypted ftp and http, and was implemented using code that is no longer actively maintained.
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
