Release highlights since 418.43:
- Updated nvidia-settings to disable line wrapping when outputting to a non-terminal in command-line mode. From GitHub pull request:
<a target='_blank' rel='noopener noreferrer' href='https://github.com/NVIDIA/nvidia-settings/pull/37'>https://github.com/NVIDIA/nvidia-settings/pull/37</a> - Updated the nvidia-settings control panel to more accurately reflect the current availability of G-SYNC or G-SYNC compatible display settings.
- Added support for the following GPUs:
- GeForce MX230
- GeForce MX250
- Fixed a bug which could sometimes cause Vulkan applications to lock up the GPU when freeing large chunks of memory on systems with PRIME enabled.
- Updated the driver to restrict use of the GPU performance counters to system administrators by default. The previous more permissive behavior can be restored by setting NVreg_RestrictProfilingToAdminUsers=0 when loading nvidia.ko.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
