Release highlights since 450.102.04:
Fixed a driver installation failure on Linux kernel 5.11 release candidates, where the NVIDIA kernel module failed to build with error “error: implicit declaration of function ‘sys_close’”.
Fixed a bug where calls to vkCreateDevice could fail on Ampere GPUs when ray tracing extensions were enabled and the application was running within the Steam Linux Runtime.
Fixed a regression that could cause display corruption when using a scaled resolution after resuming from power management suspend.
Fixed a bug that could intermittently cause NvFBC applications to fail with the error message “Unable to send exported fds”.
Fixed a bug where vkCreateSwapchain could cause the X Server to crash when an invalid imageFormat was provided.
Fixed a driver installation failure on Linux kernel 5.11 release candidates, where the NVIDIA kernel module failed to build with error “fatal error: asm/kmap_types.h: No such file or directory”.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
