Release highlights since 390.87:
* Fixed build failures which resulted in errors like "implicit declaration
of function drm_...", when building the NVIDIA DRM kernel module for Linux
kernel 5.0 release candidates.
Fixed a bug which could cause VK_KHR_external_semaphore_fd operations
to fail. -
Fixed a build failure, “implicit declaration of function
‘vm_insert_pfn’”, when building the NVIDIA DRM kernel module for Linux
kernel 4.20 release candidates. -
Fixed a build failure, “unknown type name ‘ipmi_user_t’”, when building
the NVIDIA kernel module for Linux kernel 4.20 release candidates. -
Added support for FreeBSD 12.0-RC3.
Fixed a bug that caused mode switches to fail when an SDI output board was
connected. -
Fixed a bug that could cause rendering corruption in Vulkan programs.
Added a new hook script, “pre-unload”, to the nvidia-installer hook
script system. This script, if present, will be executed before
nvidia-installer attempts to unload existing NVIDIA kernel modules. -
Fixed a bug that caused vkGetPhysicalDeviceDisplayPropertiesKHR() to
occasionally return incorrect values for physicalResolution. -
Added the synchronization state for PRIME Displays to nvidia-settings.
Fixed a bug that could prevent nvidia-xconfig from disabling the X
Composite extension on version 1.20 of the X.org X server. -
Fixed a build failure, “too many arguments to function ‘get_user_pages’”,
when building the NVIDIA kernel module for Linux kernel v4.4.168. -
Fixed a build failure, “implicit declaration of function do_gettimeofday”,
when building the NVIDIA kernel module for Linux kernel 5.0 release
candidates. -
Added a new kernel module parameter, NVreg_RestrictProfilingToAdminUsers,
to allow restricting the use of GPU performance counters to system
administrators only.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
