Release highlights since 460.56:
- Fixed a bug where using ray tracing extensions on multi-GPU setups could result in application instability if the GPUs did not match.
- Fixed an issue that prevented G-SYNC from working properly after a mode switch on Kepler-based GPUs.
- Fixed a driver installation failure on Linux kernel 5.11 release candidates, where the NVIDIA kernel module failed to build with error
error: implicit declaration of function 'sys_close'. - Fixed a bug where vkCreateSwapchain could cause the X Server to crash when an invalid imageFormat was provided.
fatal error: asm/kmap_types.h: No such file or directory.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
