Linux, Solaris, and FreeBSD driver 495.29.05 [beta]
Release highlights since 470.74:
  • Added support for the GBM API. This adds the new symlink nvidia-drm_gbm.so pointing to the file libnvidia-allocator.so.VERSION to implement a GBM backend driver usable with the GBM loader from the Mesa project version 21.2 and above, as well as the files libnvidia-egl-gbm.so.1.1.0 and 15_nvidia_gbm.json, which implement EGL support for the GBM platform (EGL_KHR_platform_gbm).
  • Add indicator for Resizable BAR support on compatible systems.
  • Fixed a bug that could cause the X server to crash when starting a new server generation on PRIME configurations.
  • Removed support for NvIFROpenGL. This functionality was deprecated in the 470.xx driver release.
  • Removed libnvidia-cbl.so from the driver package. This functionality is now provided by other driver libraries.
  • Changed the minimum required Linux kernel version from 2.6.32 to 3.10.
  • Updated nvidia.ko to load even if no supported NVIDIA GPUs are present when an NVIDIA NVSwitch device is detected in the system. Previously, nvidia.ko would fail to load into the kernel if no supported GPUs were present.
[README | Linux x86_64 | Solaris | FreeBSD x86_64]
