I would like to ask a question related to the live-source setting and streammux configuration.
According to documentation, we set the live-source to 1 when the streams are live. Sources term here is RTSP Streams and USB Camera ? Correct me if I was wrong.
Another question is that, if I have a primary detector with only accept the input width (640) and input height (480), should I set the width and height of streammux to 640x480?
Is there any relationship between the frames outputted from streammux and input frames to primary detector? Does the deepstream apply any pre-processing steps?
[streammux]
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version 7.11
• NVIDIA GPU Driver Version (valid for GPU only) 460
• Issue Type( questions, new requirements, bugs) Questions
