The introduction of llama3.1 caused an issue to Ollama. The ollama code maintainer already addressed the problem.
When attempting to load a instruct version the error “done_getting_tensors: wrong number of tensors; expected 292, got 291” shows up in the log file (see I can't run llama3.1 · Issue #6048 · ollama/ollama · GitHub )
We need an update to dustynv/ollama container @dusty_nv
Thank you for all your help!!!
Hi @pontual , see the GitHub issue here for the updated container image:
opened 05:57PM - 08 Aug 24 UTC
I just installed the containers and pulled the ollama docker.. so far it … runs, but it cannot load the new models, as it has the version 0.1.46-0-gbc42e60 but it requires at least the version 0.3x to be able to load the new models.
I get the following error message, when I try to load llama3.1:
root@ubuntu:/# ollama pull llama3.1
pulling manifest
Error: pull model manifest: 412:
The model you are attempting to pull requires a newer version of Ollama.
Please download the latest version at:
https://ollama.com/download
How can I update the ollama within the container to a newer version?
Also if you have NVME for enough storage, you can rebuild the container as needed.
I tried to build ollama using: jetson-containers build --name ollamatest ollama but got some issues.
For example I got
Blockquote
Step 11/21 : RUN bash gen_linux.sh
—> Running in 37685aaea9d2
set -o pipefail
compress_pids=
Starting linux generate script
echo ‘Starting linux generate script’
‘[’ -z /usr/local/cuda/bin/nvcc ‘]’
COMMON_CMAKE_DEFS=‘-DCMAKE_SKIP_RPATH=on -DBUILD_SHARED_LIBS=on -DCMAKE_POSITION_INDEPENDENT_CODE=on -DGGML_NATIVE=off -DGGML_AVX=on -DGGML_AVX2=off -DGGML_AVX512=off -DGGML_FMA=off -DGGML_F16C=off -DGGML_OPENMP=off’
++ dirname gen_linux.sh
source ./gen_common.sh
init_vars
case “${GOARCH}” in
GOARCH must be set
this script is meant to be run from within go generate
echo ‘GOARCH must be set’
echo ‘this script is meant to be run from within go generate’
exit 1
The command ‘/bin/sh -c bash gen_linux.sh’ returned a non-zero code: 1
File “/usr/lib/python3.10/runpy.py”, line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/lib/python3.10/runpy.py”, line 86, in _run_code
exec(code, run_globals)
File “/home/rp/jetson-containers/jetson_containers/build.py”, line 103, in
build_container(args.name, args.packages, args.base, args.build_flags, args.simulate, args.skip_tests, args.test_only, args.push, args.no_github_api)
File “/home/rp/jetson-containers/jetson_containers/container.py”, line 143, in build_container
status = subprocess.run(cmd.replace(NEWLINE , ’ ‘), executable=’/bin/bash’, shell=True, check=True)
File “/usr/lib/python3.10/subprocess.py”, line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘DOCKER_BUILDKIT=0 docker build --network=host --tag ollamatest:r36.3.0-ollama --file /home/rp/jetson-containers/packages/llm/ollama/Dockerfile --build-arg BASE_IMAGE=ollamatest:r36.3.0-cuda --build-arg OLLAMA_REPO=“ollama/ollama” --build-arg OLLAMA_BRANCH=“main” --build-arg GOLANG_VERSION=“1.22.1” --build-arg CMAKE_VERSION=“3.22.1” --build-arg JETPACK_VERSION=“6.0” --build-arg CMAKE_CUDA_ARCHITECTURES=“87” /home/rp/jetson-containers/packages/llm/ollama 2>&1 | tee /home/rp/jetson-containers/logs/20240821_153103/build/ollamatest_r36.3.0-ollama.txt; exit ${PIPESTATUS[0]}’ returned non-zero exit status 1.
rp@orinnx:~/jetson-containers$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
92127f8f8bcb 17 minutes ago 7.23GB
ollamatest r36.3.0-cuda 7bb06ca0c060 18 minutes ago 6.6GB
ollamatest r36.3.0-build-essential c70190deb319 23 minutes ago 723MB
ubuntu 22.04 7f965f3f8aae 8 days ago 69.2MB
Hi @pontual , it looks like $GOARCH started to need being set in the build environment from an ollama change a couple days ago - added that in jetson-containers commit 9fd7681 and rebuilt/pushed the latest version here: dustynv/ollama:r36.2.0
@dusty_nv I can now build the image, thank you. But neither the image you produce nor the one I created is capable of pulling llama3.1 images.
root@orinnx:/# ollama pull llama3.1:8b-instruct-q4_K_S
pulling manifest
root@orinnx:/# ollama -v gives “ollama version is 6bd8a4b”.
I am able to pull images by using your older image: dustynv/ollama:r36.3.0
Hi @pontual , sorry for the delay - it looks like others were able to get it working by setting the ollama version to 3.7 -
pulling manifest
system
Closed
October 9, 2024, 2:49am
9
