Hi all,
I wanted to know how can I flash a new kernel and DTB to the EMMC without flashing the File System again, using Jetpack 3.2.1.
I’m currently using below command to flash my Kernel and DTB, however the previously built system.img is also flashed.
sudo ./flash.sh -r -d kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb -K kernel/Image jetson-tx2 mmcblk0p1
This is a problem because any change made on the FS in the EMMC is overwritten when I need to flash the Kernel and the DTB
Thanks in advance for your help.
Looks like this patch didn’t make it in to R28.2.1. You’ll need to see this:
https://devtalk.nvidia.com/default/topic/1036286/jetson-tx1/flashing-just-dtb-on-28-2-and-tx1/post/5264465/#5264465
Basically there is an option (“DTB|RP1”) lumping “DTB” and “RP1” into a single code block, and this needs to be separated into separate options. It starts at line 1804 on flash.sh of R28.2.1.
It’ll look something like this:
1803 APP) target_partfile="${localsysfile}"; ;;
1804 #PATCH DTB|RP1) target_partfile="${dtbfilename}";
1805 # https://devtalk.nvidia.com/default/topic/1036286/jetson-tx1/flashing-just-dtb-on-28-2-and-tx1/post/5264465/#5264465
1806 DTB) target_partfile="${dtbfilename}";
1807 need_sign=1;
1808 sigext=dtb;
1809 ;;
1810 RP1) target_partfile="${dtbfilename}";
1811 need_sign=1;
1812 sigext=dtb;
1813 if [ "${tegraid}" = "0x21" ]; then
1814 sigheader=1;
1815 fi;
1816 ;;
1817 EFI) target_partfile="${localefifile}"; ;;
hello CarlosR92,
you’ll need the changes in comment #2 to update the flash.sh script.
also, the “-d” option would specify the device tree path then flashing the whole image.
you should use the “-k” option instead.
for example, here’s the command to flash the kernel partition only.
sudo ./flash.sh -r -k kernel jetson-tx2 mmcblk0p1
