Loaded runtime CuDNN incompatible with version used to compile source
Hi everyone,
I have the common issue : Loaded runtime CuDNN library: 8.0.5 but source was compiled with: 8.1.0
But I cannot solve it, and more problematic I do not know where there is a loaded runtime CuDNN lib version 8.0.5 as I have installed myself the 8.1.x version and there is not other that I am aware of.
My config:
Nvidia
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Mon_May__3_19:41:42_Pacific_Daylight_Time_2021
Cuda compilation tools, release 11.3, V11.3.109
Build cuda_11.3.r11.3/compiler.29920130_0
Tensorflow
tensorflow.version = 2.5.0
build.build_info[‘cuda_version’]) = 64_112
build.build_info[‘cudnn_version’]) = 64_8
I have installed
cudnn-11.2-windows-x64-v8.1.1.33 → same issue
Where can a version 8.0.5 can be found???
Need help now :-)
Best regards
Jerome
I can only add, that I have the exact same issue:
E tensorflow/stream_executor/cuda/cuda_dnn.cc:352] Loaded runtime CuDNN library: 8.0.5 but source was compiled with: 8.1.0. CuDNN library needs to have matching major version and equal or higher minor version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
My libs are:
TensorFlow 2.5.0
Cuda 11.2
cuDNN 8.1.1
Hi @j_massot , Apologies for delayed response, Are you still facing the issue.
I have the exact same error, with the same lib versions
For everyone experiencing similar issues. In my case, I had loaded torch and tensorflow simultaneously resulting in the above error as pytorch ships with its version of cudnn.
How did you solve it then? Same problem here.
Loaded runtime CuDNN library: 8.5.0 but source was compiled with: 8.6.0. CuDNN library needs to have matching major version and equal or higher minor version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
