• Hardware Platform (GPU)
• DeepStream Version 5.0
• TensorRT Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) 450
Want to load YOLOv4 model on deepstream-5.0 with triton inference server.
Generated a YOLO model with trt-ncg container 20.03 using jkjung repo
config_yolo4.txt
infer_config {
unique_id: 5
gpu_ids: [0]
max_batch_size: 1
backend {
inputs: [ {
outputs: [
{name: "(Unnamed Layer* 506) [PluginV2IOExt]_output_0"},
{name: "(Unnamed Layer* 507) [PluginV2IOExt]_output_0"},
{name: "(Unnamed Layer* 508) [PluginV2IOExt]_output_0"}
trt_is {
model_name: "yolo-1"
version: -1
model_repo {
root: "/yolo/sec-models"
log_level: 3
strict_model_config: true
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
tensor_name: "000_net"
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 1.0
channel_offsets: [0, 0, 0]
postprocess {
labelfile_path: "/yolo/sec-models/yolo-1/labels.txt"
detection {
num_detected_classes: 8
nms {
confidence_threshold: 0.5
iou_threshold: 0.3
extra {
copy_input_to_host_buffers: false
custom_lib {
path: "/yolo/libyolo_layer.so"
input_control {
process_mode: PROCESS_MODE_FULL_FRAME
interval: 0
output_control {
detect_control {
default_filter { bbox_filter { min_width: 32, min_height: 32 } }
deepstream-app.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=kitti-trtis
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file:///yolo/internal_test.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
#(0): nvinfer; (1): nvinferserver
plugin-type=1
#infer-raw-output-dir=trtis-output
batch-size=1
interval=0
gie-unique-id=1
config-file=config_yolov4.txt
[tests]
file-loop=0
triton-config.pbtxt
platform: "tensorrt_plan"
max_batch_size: 1
input [
data_type: TYPE_FP32
dims: [1, 3, 608, 608 ]
output [
dims: [1,121296,1,1]
dims: [1,30324,1,1]
dims: [1,7581,1,1]
instance_group [
count:1
kind: KIND_GPU
error
root@aec8e9bcb8ea:/yolo/samples/configs/deepstream-app-trtis# deepstream-app -c source1_primary_detector.txt
2021-01-29 13:30:24.897592: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.2
0:00:03.024388887 1883 0x7f7af0002390 WARN nvinferserver gstnvinferserver_impl.cpp:248:validatePluginConfig:<primary_gie> warning: Configuration file unique-id reset to: 1
I0129 13:30:26.978691 1883 metrics.cc:164] found 1 GPUs supporting NVML metrics
I0129 13:30:26.984180 1883 metrics.cc:173] GPU 0: Tesla P100-SXM2-16GB
I0129 13:30:26.984465 1883 server.cc:120] Initializing Triton Inference Server
I0129 13:30:27.103776 1883 pinned_memory_manager.cc:197] Pinned memory pool is created at '0x7f7acc000000' with size 268435456
I0129 13:30:27.104132 1883 graphdef_backend_factory.cc:48] Create GraphDefBackendFactory
I0129 13:30:27.104166 1883 savedmodel_backend_factory.cc:48] Create SavedModelBackendFactory
I0129 13:30:27.104198 1883 netdef_backend_factory.cc:46] Create NetDefBackendFactory
I0129 13:30:27.104211 1883 plan_backend_factory.cc:48] Create PlanBackendFactory
I0129 13:30:27.104222 1883 plan_backend_factory.cc:55] Registering TensorRT Plugins
I0129 13:30:27.104252 1883 logging.cc:52] Plugin creator registration succeeded - ::GridAnchor_TRT
I0129 13:30:27.104274 1883 logging.cc:52] Plugin creator registration succeeded - ::NMS_TRT
I0129 13:30:27.104295 1883 logging.cc:52] Plugin creator registration succeeded - ::Reorg_TRT
I0129 13:30:27.104310 1883 logging.cc:52] Plugin creator registration succeeded - ::Region_TRT
I0129 13:30:27.104331 1883 logging.cc:52] Plugin creator registration succeeded - ::Clip_TRT
I0129 13:30:27.104346 1883 logging.cc:52] Plugin creator registration succeeded - ::LReLU_TRT
I0129 13:30:27.104359 1883 logging.cc:52] Plugin creator registration succeeded - ::PriorBox_TRT
I0129 13:30:27.104373 1883 logging.cc:52] Plugin creator registration succeeded - ::Normalize_TRT
I0129 13:30:27.104395 1883 logging.cc:52] Plugin creator registration succeeded - ::RPROI_TRT
I0129 13:30:27.104413 1883 logging.cc:52] Plugin creator registration succeeded - ::BatchedNMS_TRT
I0129 13:30:27.104424 1883 logging.cc:52] Plugin creator registration succeeded - ::FlattenConcat_TRT
I0129 13:30:27.104435 1883 logging.cc:52] Plugin creator registration succeeded - ::CropAndResize
I0129 13:30:27.104444 1883 logging.cc:52] Plugin creator registration succeeded - ::DetectionLayer_TRT
I0129 13:30:27.104452 1883 logging.cc:52] Plugin creator registration succeeded - ::Proposal
I0129 13:30:27.104466 1883 logging.cc:52] Plugin creator registration succeeded - ::ProposalLayer_TRT
I0129 13:30:27.104476 1883 logging.cc:52] Plugin creator registration succeeded - ::PyramidROIAlign_TRT
I0129 13:30:27.104492 1883 logging.cc:52] Plugin creator registration succeeded - ::ResizeNearest_TRT
I0129 13:30:27.104502 1883 logging.cc:52] Plugin creator registration succeeded - ::Split
I0129 13:30:27.104514 1883 logging.cc:52] Plugin creator registration succeeded - ::SpecialSlice_TRT
I0129 13:30:27.104530 1883 logging.cc:52] Plugin creator registration succeeded - ::InstanceNormalization_TRT
I0129 13:30:27.104542 1883 onnx_backend_factory.cc:53] Create OnnxBackendFactory
I0129 13:30:27.114051 1883 libtorch_backend_factory.cc:46] Create LibTorchBackendFactory
I0129 13:30:27.114091 1883 custom_backend_factory.cc:46] Create CustomBackendFactory
I0129 13:30:27.114103 1883 ensemble_backend_factory.cc:47] Create EnsembleBackendFactory
I0129 13:30:27.115278 1883 server_status.cc:55] New status tracking for model 'yolo-1'
I0129 13:30:27.115373 1883 model_repository_manager.cc:568] AsyncLoad() 'yolo-1'
I0129 13:30:27.115399 1883 model_repository_manager.cc:622] TriggerNextAction() 'yolo-1' version 1: 1
I0129 13:30:27.115411 1883 model_repository_manager.cc:660] Load() 'yolo-1' version 1
I0129 13:30:27.115421 1883 model_repository_manager.cc:680] loading: yolo-1:1
I0129 13:30:27.115545 1883 model_repository_manager.cc:735] CreateInferenceBackend() 'yolo-1' version 1
W0129 13:30:28.986633 1883 metrics.cc:276] failed to get energy consumption for GPU 0, NVML_ERROR 3
I0129 13:30:30.576018 1883 logging.cc:52] Deserialize required 2948784 microseconds.
I0129 13:30:30.576063 1883 plan_backend.cc:267] Creating instance yolo-1_0_0_gpu0 on GPU 0 (6.0) using model.plan
W0129 13:30:30.579901 1883 logging.cc:46] Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
I0129 13:30:30.579956 1883 plan_backend.cc:453] Detected 000_net as execution binding for yolo-1
I0129 13:30:30.579978 1883 plan_backend.cc:453] Detected (Unnamed Layer* 506) [PluginV2IOExt]_output_0 as execution binding for yolo-1
I0129 13:30:30.580005 1883 plan_backend.cc:453] Detected (Unnamed Layer* 507) [PluginV2IOExt]_output_0 as execution binding for yolo-1
I0129 13:30:30.580018 1883 plan_backend.cc:453] Detected (Unnamed Layer* 508) [PluginV2IOExt]_output_0 as execution binding for yolo-1
I0129 13:30:30.580380 1883 plan_backend.cc:599] Created instance yolo-1_0_0_gpu0 on GPU 0 with stream priority 0
I0129 13:30:30.580506 1883 dynamic_batch_scheduler.cc:233] Starting dynamic-batch scheduler thread 0 at nice 5...
I0129 13:30:30.580601 1883 plan_backend.cc:298] plan backend for yolo-1
name=yolo-1
contexts:
name=yolo-1_0_0_gpu0, gpu=0, max_batch_size=1
bindings:
0: max possible byte_size=4435968, buffer=0x7f7a77000000 ]
1: max possible byte_size=485184, buffer=0x7f7aa7c4c000 ]
2: max possible byte_size=121296, buffer=0x7f7aa7cc2800 ]
3: max possible byte_size=30324, buffer=0x7f7aa7ce0200 ]
I0129 13:30:30.592899 1883 model_repository_manager.cc:837] successfully loaded 'yolo-1' version 1
I0129 13:30:30.592927 1883 model_repository_manager.cc:622] TriggerNextAction() 'yolo-1' version 1: 0
I0129 13:30:30.592943 1883 model_repository_manager.cc:637] no next action, trigger OnComplete()
I0129 13:30:30.592988 1883 model_repository_manager.cc:492] GetVersionStates() 'yolo-1'
INFO: infer_trtis_backend.cpp:206 TrtISBackend id:1 initialized model: yolo-1
I0129 13:30:30.595602 1883 model_repository_manager.cc:511] GetInferenceBackend() 'yolo-1' version -1
I0129 13:30:30.595713 1883 plan_backend.cc:1499] Running yolo-1_0_0_gpu0 with 1 request payloads
I0129 13:30:30.595742 1883 plan_backend.cc:2131] Optimization profile default [0] is selected for yolo-1_0_0_gpu0
I0129 13:30:30.595800 1883 plan_backend.cc:1744] Context with profile default [0] is being executed for yolo-1_0_0_gpu0
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
WARNING from primary_gie: Configuration file unique-id reset to: 1
Debug info: gstnvinferserver_impl.cpp(248): validatePluginConfig (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie
** INFO: <bus_callback:167>: Pipeline running
I0129 13:30:30.836391 1883 model_repository_manager.cc:511] GetInferenceBackend() 'yolo-1' version -1
ERROR: infer_trtis_server.cpp:111 TRTIS: TrtServerRequest failed to create inference request providerV2, trtis_err_str:INVALID_ARG, err_msg:unexpected shape for input '000_net' for model 'yolo-1'. Expected [1,3,608,608], got [3,608,608]
ERROR: infer_trtis_server.cpp:725 TRTIS failed to create request for model: yolo-1 version:-1
ERROR: infer_trtis_backend.cpp:498 TRT-IS run failed to create request for model: yolo-1
ERROR: infer_trtis_backend.cpp:478 TRT-IS failed to run inference on model yolo-1, nvinfer error:NVDSINFER_TRTIS_ERROR
0:00:06.886390008 1883 0x7f7a5c011950 WARN nvinferserver gstnvinferserver.cpp:519:gst_nvinfer_server_push_buffer:<primary_gie> error: inference failed with unique-id:1
ERROR from primary_gie: inference failed with unique-id:1
Debug info: gstnvinferserver.cpp(519): gst_nvinfer_server_push_buffer (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie
I0129 13:30:30.839594 1883 model_repository_manager.cc:511] GetInferenceBackend() 'yolo-1' version -1
0:00:06.889326410 1883 0x7f7a5c011950 WARN nvinferserver gstnvinferserver.cpp:519:gst_nvinfer_server_push_buffer:<primary_gie> error: inference failed with unique-id:1
ERROR from qtdemux0: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
streaming stopped, reason custom-error (-112)
Quitting
I0129 13:30:30.971644 1883 model_repository_manager.cc:568] AsyncLoad() 'yolo-1'
I0129 13:30:30.971675 1883 model_repository_manager.cc:622] TriggerNextAction() 'yolo-1' version 1: 2
I0129 13:30:30.971701 1883 model_repository_manager.cc:701] Unload() 'yolo-1' version 1
I0129 13:30:30.971711 1883 model_repository_manager.cc:708] unloading: yolo-1:1
I0129 13:30:30.971720 1883 plan_backend.cc:88] ~PlanBackend::Context
I0129 13:30:30.980867 1883 dynamic_batch_scheduler.cc:443] Stopping dynamic-batch scheduler thread 0...
I0129 13:30:30.981041 1883 model_repository_manager.cc:814] OnDestroy callback() 'yolo-1' version 1
I0129 13:30:30.981089 1883 model_repository_manager.cc:816] successfully unloaded 'yolo-1' version 1
I0129 13:30:30.981109 1883 model_repository_manager.cc:622] TriggerNextAction() 'yolo-1' version 1: 0
I0129 13:30:30.981134 1883 model_repository_manager.cc:492] GetVersionStates() 'yolo-1'
I0129 13:30:30.989231 1883 server.cc:179] Waiting for in-flight inferences to complete.
I0129 13:30:30.989278 1883 model_repository_manager.cc:463] GetLiveBackendStates()
I0129 13:30:30.989297 1883 server.cc:194] Timeout 30: Found 0 live models and 0 in-flight requests
W0129 13:30:30.989354 1883 metrics.cc:276] failed to get energy consumption for GPU 0, NVML_ERROR 3
App run failed
W0129 13:30:32.991676 1883 metrics.cc:276] failed to get energy consumption for GPU 0, NVML_ERROR 3
