I am testing Tesla V100 using CUDA 9 and cuDNN 7 (on Windows 10).
I measured good performance for cuBLAS ~90 Tflops on matrix multiplication. However, in cuDNN I measured only low performance and no advantage of tensor cores on V100.
For example, the following code shows only ~14 Tflops. It is unacceptable taking into account NVIDIA’s marketing promises and the price of V100.
Is there parameter settings when Tesla V100 has benefit from using tensor cores in cuDNN when computing convolution?
void Check(cudnnStatus_t status)
if (status != CUDNN_STATUS_SUCCESS)
fprintf(stderr, “!!! GPU program execution error: %s\n”, cudnnGetErrorString(status));
exit(0);
void Check(cudaError_t status)
if (status != cudaSuccess)
fprintf(stderr, “!!! CUDA error\n”);
exit(0);
size_t Get_size(cudnnTensorDescriptor_t tensor_desc)
size_t size = 0;
Check(cudnnGetTensorSizeInBytes(tensor_desc, &size));
return size;
void* Alloc(size_t size)
if (size == 0) return 0;
void* x = 0;
cudaMalloc(&x, size);
return x;
void main()
cudnnHandle_t cudnn;
cudnnCreate(&cudnn);
const int c_in = 128;
const int c_out = 128;
const int xh = 128;
const int xw = 128;
const int n = 128;
const int fh = 4;
const int fw = 4;
float alpha = 0.1f, beta = 0.1f;
cudnnTensorFormat_t data_format = CUDNN_TENSOR_NCHW;
cudnnDataType_t data_type = CUDNN_DATA_HALF;
cudnnTensorDescriptor_t x_desc;
Check(cudnnCreateTensorDescriptor(&x_desc));
Check(cudnnSetTensor4dDescriptor(x_desc, data_format, data_type, n, c_in, xh, xw));
cudnnFilterDescriptor_t f_desc;
Check(cudnnCreateFilterDescriptor(&f_desc));
Check(cudnnSetFilter4dDescriptor(f_desc, data_type, data_format, c_out, c_in, fh, fw));
cudnnConvolutionDescriptor_t conv_desc;
Check(cudnnCreateConvolutionDescriptor(&conv_desc));
Check(cudnnSetConvolution2dDescriptor(
conv_desc,
0, //0, //int pad_h,
0, //0, //int pad_w,
1, //int u,
1, //int v,
1, //0, // dilation_h,
1, //0, // dilation_w,
CUDNN_CONVOLUTION,
CUDNN_DATA_FLOAT));
int n_, c_, h_, w_;
Check(cudnnGetConvolution2dForwardOutputDim(conv_desc, x_desc, f_desc, &n_, &c_, &h_, &w_));
float Gflop = (2.0f * (float)n_ * (float)h_ * (float)w_ * (float)c_out * (float)c_in * (float)fh * (float)fw) / (1000.0f * 1000.0f * 1000.0f);
printf("n_=%d c_=%d h_=%d w_=%d, Gflop=%f\n", n_, c_, h_, w_, Gflop);
cudnnTensorDescriptor_t y_desc;
Check(cudnnCreateTensorDescriptor(&y_desc));
Check(cudnnSetTensor4dDescriptor(y_desc, data_format, data_type, n_, c_, h_, w_));
cudnnConvolutionFwdAlgo_t algo = CUDNN_CONVOLUTION_FWD_ALGO_IMPLICIT_PRECOMP_GEMM;
size_t tmp_size = 0;
Check(cudnnGetConvolutionForwardWorkspaceSize(cudnn, x_desc, f_desc, conv_desc, y_desc, algo, &tmp_size));
size_t f_size = (size_t)c_out * (size_t)c_in * (size_t)fh * (size_t)fw;
printf("tmp_size: %f MB\n", tmp_size * 1.0f / (1024.0*1024.0));
printf("x_size: %f MB\n", Get_size(x_desc) * 1.0f / (1024.0*1024.0));
printf("y_size: %f MB\n", Get_size(y_desc) * 1.0f / (1024.0*1024.0));
printf("f_size: %f MB\n", f_size * 1.0f / (1024.0*1024.0));
void* x = Alloc(Get_size(x_desc));
void* f = Alloc(f_size);
void* y = Alloc(Get_size(y_desc));
void* t = Alloc(tmp_size);
void* y2 = Alloc(Get_size(y_desc));
printf("x = %p, f = %p, y = %p, t = %p\n", x, f, y, t);
const int Q = 4;
cudaStream_t stream[Q];
for (int q = 0; q < Q; q++) Check(cudaStreamCreate(&(stream[q])));
double ti = second();
int U = 10;
for (int u = 0; u < U; u++)
Check(cudnnSetStream(cudnn, stream[q]));
Check(cudnnConvolutionForward(cudnn, &alpha, x_desc, x, f_desc, f,
conv_desc, algo, t, tmp_size, &beta, y_desc, y));
for (int q = 0; q < Q; q++) Check(cudaStreamSynchronize(stream[q]));
float secs = (float)(second() - ti);
float gflops = (Gflop * U * Q) / secs;
printf("secs: %f, Tflops: %f\n", secs, gflops / 1000.0f);
