Low ViT Performance Gain on Jetson Thor Using FP8 vs FP16
Looking at the documentation, to enable fp8 operations you need some onnx surgery (inserting Q/DQ at specific locations) to trigger the right MHA (Multi-Head Attention) fusion in conjunction with fp8 precision.
However, the performance improvement is quite low for base ViT model (~20% latency reduction). It is even worse on the EfficientSAM encoder with basically no gain.
By looking at the profiling and layer info from TensorRT the FP8 seems there (even though some tactics are quite cryptic, especially the gmm_mha_v2_#weirdbitstream).
Environment
  • TensorRT Version: 10.13.3
  • NVIDIA GPU: Thor (Jetson DevKit)
  • NVIDIA Driver Version: 580.00
  • CUDA Version: 13
Relevant Files
Steps To Reproduce
Model Optimizercommit
ViT-Base FP8 onnx generation:
python3 -m modelopt.onnx.quantization --onnx_path=./vit_base_patch8_224_Opset17.onnx --quantize_mode=fp8 --output_path=./vitb_fp8.onnx
EfficientSAM-S FP8 onnx generation:
python3 -m modelopt.onnx.quantization --onnx_path=./efficientsam_s_encoder.onnx --quantize_mode=fp8 --output_path=./sam_s_fp8.onnx
ViT-Base FP8 engine generation:
trtexec --stronglyTyped --onnx=./vitb_fp8.onnx --saveEngine=./vitb_fp8.engine
trtexec --stronglyTyped --onnx=./sam_s_fp8.onnx --saveEngine=./sam_s_fp8.engine
efficientsam_s_encoder_fp8.profile.txt (14.3 KB)
efficientsam_s_encoder_fp16.profile.txt (14.0 KB)
vit_base_patch8_224_Opset17_fp8.profile.txt (13.7 KB)
vit_base_patch8_224_Opset17_fp16.profile.txt (13.3 KB)
profiles_and_layerinfo.zip (28.9 KB)
Thanks for reporting this.
We will try it locally and update you with more information.
In our test, for EfficientSAM:
FP16: 140.689 qps
FP8: 166.332 qps
Does this align with your experiment?
We set the device to maximum performance before the testing:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Yes pretty much.
For EfficientSAM (S), with the MAXN profile I have:
  • 147 fps for the fp16 engine
  • 172 fps for the fp8 engine
The gain is ~17% on my part and ~18% on yours.
Thanks for the update.
We are gathering more information about this issue with our internal team.
Will update more information with you later
Thanks for your patience.
We confirm that this is a perf bug and our internal team is working on the fix.
Will keep updating the status with you.
Thanks for the update. Reassuring to hear that a fix is on its way !
Hi, I have similar results for nvfp4 inference on Jetson Thor. With batch size 128, the nvfp4 inference latency is even larger than fp16 inference. The model I used is ViT-large, very similar to ViT-base in the post here.
And on RTX-6000 Blackwell, nvfp4 quantization can make the model much faster.
Is it also the same bug?
In addition, for ViT-Large, it has 300M parameters.
So theoretically, using nvfp4 rather than fp16, we shall have 300 * 1.5 = 450MB GPU memory saved.
However on thor, it’s only ~200MB. While on RTX-6000 Blackwell, the number looks much better.
Hi, may I ask if Thor supports nvfp4 or mxfp4 or both?
Please find the reply in the topic below:
Not sure I understand why this comes as a solution for this topic.
Could you expand on the reason it is marked as solution ?
Best,
We have reopened the topic.
Here are some updates for you:
This problem size is bound by the softmax throughput, which is done in FP32.
Hence, FP16 and FP8 are not far apart in terms of performance.
So we think the perf is reasonable (14% improvement).
