Would you be able to post the training specifications used to generate the LPDNet YoloV4 model?
Thank you!
Thank you!
Just share with you for reference. But please note that the yolov4 LPDnet model was trained about one year ago. So, some parameters are not compatible with latest TAO docker.
yolov4_config {
big_anchor_shape: "[(161.00, 80.00), (130.08, 136.36), (190.48, 184.62)]"
mid_anchor_shape: "[(121.77, 54.04), (100.00, 100.00),(87.91, 117.65)]"
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: "cspdarknet_tiny"
arch_conv_blocks: 0
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.05
freeze_bn: false
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 120
enable_qat: false
checkpoint_interval: 1
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
# resume_model_path: "/workspace/lpd/yolo_v4_tiny_result/weights/yolov4_cspdarknet_tiny_epoch_048.tlt"
# pretrain_model_path: "/workspace/tlt-experiments/tltv2_pretrain_model/resnet_18.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 640
output_height: 480
output_channel: 3
randomize_input_shape_period: 10
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
image_directory_path: "/workspace/lpd/image_640x480"
label_directory_path: "/workspace/lpd/label_640_480"
include_difficult_in_training: true
target_class_mapping {
key: "lpd"
value: "lpd"
validation_data_sources: {
image_directory_path: "/workspace/lpd/3k_testImg_640_480"
label_directory_path: "/workspace/lpd/3k_testImg_640_480_label"
