• Hardware (T4/V100/Xavier/Nano/etc) : T4
• Network Type : Yolo_v4
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Configuration of the TLT Instance
dockers: ['nvidia/tlt-streamanalytics', 'nvidia/tlt-pytorch']
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
docker_tag: v3.0-py3
• Training spec file(If have, please share here)
random_seed: 42
yolov4_config {
big_anchor_shape: "[(247.00, 178.00), (193.00, 235.00), (267.00, 299.00), (385.00, 406.00), (642.00, 614.00)]"
mid_anchor_shape: "[(108.00, 85.00), (99.00, 118.00), (146.00, 120.00), (118.00, 151.00), (158.00, 175.00)]"
small_anchor_shape: "[(45.00, 49.00), (54.00, 64.00), (76.00, 66.00), (64.00, 81.00), (80.00, 97.00)]"
box_matching_iou: 0.3
arch: "resnet"
nlayers: 50
arch_conv_blocks: 2
loss_loc_weight: 5.0
loss_neg_obj_weights: 50.0
loss_class_weights: 0.9
label_smoothing: 0.1
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 1
num_epochs: 10
enable_qat: true
checkpoint_interval: 1
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: "/workspace/tlt-experiments/yolo_v4/pretrained_resnet50/tlt_pretrained_object_detection_vresnet50/resnet_50.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 1
matching_iou_threshold: 0.4
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.4
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1920
output_height: 1024
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
label_directory_path: "/workspace/tlt-experiments/data/training/label_2"
image_directory_path: "/workspace/tlt-experiments/data/training/image_2"
include_difficult_in_training: true
target_class_mapping {
key: "안전벨트 착용"
value: "Belt on"
key: "안전벨트 미착용"
value: "Belt off"
key: "안전화 착용"
value: "Shoes on"
key: "안전모 착용"
value: "Helmet on"
validation_data_sources: {
label_directory_path: "/workspace/tlt-experiments/data/val/label"
image_directory_path: "/workspace/tlt-experiments/data/val/image"
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
training results :
Producing predictions: 100%|████████████████| 1665/1665 [06:25<00:00, 4.32it/s]
Start to calculate AP for each class
belt off AP 0.0
belt on AP 0.0
helmet on AP 0.0
shoes on AP 0.0
mAP 0.0
Validation loss: 0.00021867455646127195
During training, I watched the loss close to 0, but the inference result always yields 0 mAP.
Is there anything I need to edit in the spec file?
Also, is it correct to set the nlayers of the spec file to 18 for resnet18 and 50 for resnet50 depending on the backbone?
We trained on 4 classes, and all classes have a similar number of instances.
