Hi - I’m trying to build a kernel on my Jetson Nano 2GB to include HDMI to CSI driver (for the Toshiba TC358743 chip) in the device tree and I’m using this webpage as a resource.
When I get to the “Combining kernel and dtb” section and run this line:
make -C kernel/kernel-4.9/ ARCH=arm64 O=$TEGRA_KERNEL_OUT LOCALVERSION=-tegra CROSS_COMPILE=${TOOLCHAIN_PREFIX} -j8 --output-sync=target zImage
I get this output:
make[1]: Entering directory '/home/bsg1/Linux_for_Tegra/source/public/build'
arch/arm64/Makefile:49: LSE atomics not supported by binutils
/home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/gcc-version.sh: line 25: /home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: cannot execute binary file: Exec format error
/home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/gcc-version.sh: line 26: /home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: cannot execute binary file: Exec format error
/home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 1: /home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: cannot open @@: No such file
/home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 1: /home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: ELF: not found
/home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 3: /home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Syntax error: "(" unexpected
make[1]: Leaving directory '/home/bsg1/Linux_for_Tegra/source/public/build'
GEN ./Makefile
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
Using /home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9 as source for kernel
CC scripts/mod/empty.o
/bin/sh: 1: /home/bsg1/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error
/home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/Makefile.build:335: recipe for target 'scripts/mod/empty.o' failed
make[3]: *** [scripts/mod/empty.o] Error 2
make[3]: *** Waiting for unfinished jobs....
CC scripts/mod/devicetable-offsets.s
/home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/Makefile.build:155: recipe for target 'scripts/mod/devicetable-offsets.s' failed
make[3]: *** [scripts/mod/devicetable-offsets.s] Error 2
/home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9/scripts/Makefile.build:649: recipe for target 'scripts/mod' failed
make[2]: *** [scripts/mod] Error 2
make[2]: *** Waiting for unfinished jobs....
/home/bsg1/Linux_for_Tegra/source/public/kernel/kernel-4.9/Makefile:579: recipe for target 'scripts' failed
make[1]: *** [scripts] Error 2
Makefile:171: recipe for target 'sub-make' failed
make: *** [sub-make] Error 2
Does the message LSE atomics not supported by binutils indicate what the issue is? I searched around for this but couldn’t find any solutions that helped.
Thanks in advance!
Jamie
