Description
We are trying to convert a lstm model running on a 4d tensor to tensorrt.We chose to intialize the h0 and c0 with mean of the tensor. That’s why the code is quite long. For more details the pytorch script is also provided. We want to use the multithreading functionality so we need more than 1 optimization profile. but the code gives
[TensorRT] ERROR: 2: [standardEngineBuilder.cpp::makeEngineFromGraph::1288] Error Code 2: Internal Error (Assertion engineRegions.count(it->name) == 0 failed.)
if I add the for loop to add multiple optimization profiles to config.
Environment
Docker Env:nvcr.io/nvidia/tensorrt:21.02-py3
GPU Type: tried both gtx 2080ti and gtx3090
Nvidia Driver Version: 470.57.02
PyTorch Version (if applicable): tried with pytorch1.4 and 1.6 and 1.7 with 1.7 has an no output bug when exporting
Relevant Files
Steps To Reproduce
run
python export2onnx.py
you can skip it since I also provide the onnx file
then just run
python onnx2tensor.py
full error message
for to onnx script there are some warning:
Converting a tensor to a Python integer might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
con_h = torch.unsqueeze(con_h, 2).repeat(1, 1, int(feature_h), 1)
/home/agent_m/temp/minimal_case/lstm.py:54: TracerWarning: Converting a tensor to a Python integer might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
con_c = torch.unsqueeze(con_c, 2).repeat(1, 1, int(feature_h), 1)
/home/agent_m/miniconda3/envs/pipeline_env_3/lib/python3.6/site-packages/torch/onnx/symbolic_opset9.py:1668: UserWarning: Exporting a model to ONNX with a batch_size other than 1, with a variable length with LSTM can cause an error when running the ONNX model with a different batch size. Make sure to save the model with a batch size of 1, or define the initial states (h0/c0) as inputs of the model.
"or define the initial states (h0/c0) as inputs of the model. ")
for tensorrt script:
[TensorRT] WARNING: onnx2trt_utils.cpp:362: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[TensorRT] WARNING: onnx2trt_utils.cpp:390: One or more weights outside the range of INT32 was clamped
Completed parsing of ONNX file
onnx2tensorrt.py:28: DeprecationWarning: Use build_serialized_network instead.
engine = builder.build_engine(network, config=trt_config)
[TensorRT] WARNING: Detected invalid timing cache, setup a local cache instead
File "onnx2tensorrt.py", line 39, in <module>
engine, context = build_engine('onnx_out.onnx')
File "onnx2tensorrt.py", line 29, in build_engine
context = engine.create_execution_context()
AttributeError: 'NoneType' object has no attribute 'create_execution_context'
I did int(feature_h) only because I tried to debug myself and tried to figure out if those dynamic numbers are the problems, it turns out they are not.
